Which route to go on hydraulic steering? >
Old 04-11-2014 | 12:49 PM
I installed a single full hydraulic system on my 2002 280 Velocity last spring. All that I can say is WOW. It is a completely different boat now. The boat goes exactly where you steer it. The boat does not wander at all anymore. It is a real pleasure to drive now.
Give Kenny at Velocity a call. He set me up with the complete system, all the hoses were premade to fit my boat. The price wasn't bad. Give Kenny a call!
An add on system will still wonder because of the slack in the cables. There is a reason why they sell both.
underpsi68 is offline
Old 04-11-2014 | 06:03 PM
Lot of years ago I added a full Hydraulic system to a Velocity I had. My suggestion to you would be to go to IMCO and do a full system, do the helm and dual rams if the budget allows, if not a single ram on the transom will do fine.
My opinion has always been that a good system is warranted on anything that runs past 60, for the handling advantages, not to mention the added safety.
RaggedEdge is offline
Old 04-11-2014 | 09:48 PM
On my second Velocity 260. Installed single ram full hydraulic systems to both boats. What a difference in the handling on Velocity's. Those boats should come standard with it. First system was a marine machine the second system is a mayfair. Imco, zieger, mayfair whatever you choose go full, no add on bull****, you will not be unhappy.
VELOCITYBOY is offline
Old 04-12-2014 | 07:27 AM
If you keep records of how much you spend trying to piece a system together you will be about 90 percent of kit price. Unless you have an inside connection to hydraulic supply.
looseconnection is offline
Old 04-12-2014 | 07:32 AM
Full hydraulic, dual ram. You can take your hands off the wheel at any speed. Anything less and I think you will have regrets eventually.
thirdchildhood is offline
