Nothing wrong with stepping up to SFI rated stuff......unless it's Procomp crap.
Not a real advantage leaving the water, it will change rpm easier with less inertia if the throttle isn't pulled back. It should be a big advantage on reentry for any mismatch of rpm to boat speed.
I doubt you'll get the boat out of gear at 700-880 RPM idle and at the at speed going into neutral, your going to eventually break something. The Alpha shift scenario is totally different than a Bravo or TRS. The lower the idle speed the easier it is on the outdrive.
| All times are GMT -5. The time now is 06:41 PM. |
