valve seals
Old 04-19-2014 | 08:19 PM
Default valve seals
Can anyone explain why the mercruiser manual #9 says do not install valve seals on exhaust valves?
hbarnette is offline
Old 04-19-2014 | 09:31 PM
some believe that the little extra oil helps lubricate the guide to prevent siezing
proboat-wes is offline
Old 04-19-2014 | 09:50 PM
Agreed, I don't use them at all Intake and Exhaust, better for the guides,
abones is offline
Old 04-19-2014 | 10:46 PM
The exhaust has pressure that tends to push the oil away from the guide while running. They do tend to run a bit dry especially at low rpm. At most, I use umbrellas on the exhaust side, or factory O-rings on small blocks.
The intake, having vacuum, tends to pull oil in the guide just fine, and needs a little metering with either a positive seal, or an umbrella if the guide is tall enough to hide under it.
rev.ronnie is offline
Old 04-20-2014 | 08:09 AM
35fountain's Avatar
I have perfect seals on the intake valves and none on the exhaust. A small puff of smoke on start up only. keeps guides lubed
35fountain is offline
Old 04-20-2014 | 08:51 AM
PC seals tend to leak a little more that umbrella's..
ezstriper is offline
Old 04-21-2014 | 10:27 PM
If you are using a quality, flourolastomer seal in a metal case, they are very effective at sealing. They don't "go away" over time. Now a rubber, or Teflon type positive seal will eventually loosen on the valve and let more oil by as Teflon wears and full rubber gets hardened.
The umbrellas are just as the name states...they shed the oil away from the valve allowing it to catch a mist from all around it. They are pretty much the same forever unless they crumble up and fall to pieces. I like the hard plastic ones or the plastic/rubber type. I don't like the full rubber ones...they fall apart over time.
