which oil filter do you >
Old 04-26-2014 | 04:19 AM
NAPA Platinum 41060
Valvoline VR1
Rattlesnake Jake is offline
Old 04-26-2014 | 07:11 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Do a search. This has been discussed literally hundreds of times here on OSO.
The favorite among the masses here at OSO is the Wix oil filter, which is sold under the Napa label.
Sydwayz is offline
Old 04-26-2014 | 07:17 AM
wix 51060r,i buy them by the case.
mike tkach is offline
Old 04-26-2014 | 10:30 AM
Wix Racing (R)
thirdchildhood is offline
Old 04-26-2014 | 10:40 AM
For others, the wix 51069r is needed to fit between the remote and the exhaust manifold. Shorter version of the 60r.
Pismo10 is offline
Old 04-26-2014 | 03:52 PM
Moroso 22460
OPS VZLA is offline
Old 04-26-2014 | 04:04 PM
Napa Gold 1060, its the Wix filter, learned that here though. It isn't the r style filter from Wix from what I was told, but was also told the difference between the 51060 Wix(napa gold 1060) and the 51060r is the psi capabilities, is made more robust. Guy at Napa told me that, even though he seemed knowledgeable regarding Wix and the napa filter, take it for what it is.
ealesh33 is offline
Old 04-26-2014 | 04:15 PM
Originally Posted by hangem out 2dry
which oil filter do you prefer to replace fram hp4
Wish I could help you with a different brand and #, but I will stick with the Fram HP-4s they have worked great for me for a Very Very long time. No need for me to look elsewhere.
abones is offline
Old 04-27-2014 | 01:55 PM
Have you ever cut a fram filter open?
PurdueCAT is offline
Old 04-27-2014 | 04:37 PM
Never had a lower end failure in 45 years, so No I never had any reason to cut any filter apart. Been a mechanic most of my life and guess if it worked all these years why change now. But I tell me what you know about the main reason to make the change!
abones is offline
