Single shifter to Dual what ends/calbes needed?
Hi guys. I have a set of what I think are mercury zero effort controls with trim on the throttle. What I have now is one lever. I want to switch to the zero efforts I just bought. Wiring not a problem. Mounting not a problem. Control cables kinda got me. This is a link on ebay to show whatt I want to install. I only do htis since I cant post pics here. http://www.ebay.com/itm/Kiekhaefer-m...86#ht_25wt_985
What cables or ends do I need to get to make this work. If you can, please post links to some places that sell the parts I will need. Not sure if I can just switch the ends or if I will need all new cables and ends.
Boat has a bravo1 with the shift bracket on exhaust. Cables say teleflex on them and have a plastic end on the motor side. This is added info to help with your answers. THanks
Thanks Mild Thunder. But man there not cheap for that little peice of **$&. And you need more then one. I am not cheap but this is killing me to spend 38 bucks each on these. There has to be a cheaper way. Thanks again now I know what I need at least. I will also need new cables since mine dont have screw on ends.
Mine have been converted to run Hiems. Got them used with the heims installed. Doesnt look like it would take much to do it. I believe (double check) the 33c cable is 10-32. summit, jegs etc should have them for 10~12 bucks apiece in stainless. Here is a link to the best price your going to find on 33c cables http://www.ebay.com/usr/marinegogo?_...p2047675.l2559
