-   -   K plane mounting pins frozen (https://www.offshoreonly.com/forums/general-q/311590-k-plane-mounting-pins-frozen.html)
Young Performance 05-01-2014 12:39 AM
In this situation, I would pull them off, throw them away and tell the customer that he needs new ones cause his are broke.:lolhit:
I've run into this a few times. I removed them and cut the pin between every part of the hinge with a band saw. It's real easy to control it on the band saw and it cuts right through it. I then heated each section one at a time with it in the press with a little tension on that section of the pin. Once you get some heat in the tab, the pin will cut loose and you can press it right out.
Eddie
