Help, Motor won't start. Merc 454 Mag EFI
#51
OK BACK TO THE BOX....If you test for power their at all 3 fuse leads on both sides,,all those leads are triggered from the ecm...the landyard safety tether that goes to your wrise also goes to the ecm which powers up the ecm..check the circuit brakers and what ever side of the tether feeds power to the tether or lantyard to power up the fuel side of the ecm that provides power to the fuel pump..like i said some boats have more then one fuse panel..
if it all checks out either your ignition module is bad or your ecm took a crap..
#52
Is your boat on a lift at LOTO? If so what MM?
#54
I went through all the elec connections and fuses I could find, my boat has never seen salt water and has never sit in the water overnight. Not to be egotistical but its pretty dang clean everywhere. I have a few wiring diagrams and troubleshoot flow chart now so hopefully will lead to prob. I have the VST and removed the elec pump and it was clean inside, so going to back track electrical as the guys mentioned. Ignition Switch isnt talking to ECU and Fuel Pump so I'm guessing it's somewhere between there. They were both running 3 weeks ago after de-winterization. Thanks for your suggestion
#56
No man I have been out of state since that weekend. I called a local tech and hes gonna try and diagnose it and see if it throws a code. He seems to think ECM by what I was telling him but I know that story so won't fall for it just yet. I ordered a new ignition and kill switch just incase it's one of those. I had battery problems that day and had to charge battery, I was wondering how sensative EFI is to weak battery. It was plenty to crank it and shock the **** outta me checking for spark but doesnt mean it's enough to power the system right?
#58
Nice to hear you found the problem, don't know if thats a good price or not but for the two prices you posted I would get the new one since it isn't all that much more. Send it back ttt and see if someone has one at a better price.
