MSD Dist cap center post Failing???? >
Old 05-12-2014 | 05:56 PM
Strip Poker 388's Avatar
Rob
Originally Posted by Griff
How many hours is that??? My stock Merc ones were in better shape with over 300hrs.
The Sierra ones are even better than the Merc stuff and have brass terminals and only cost about $30 for cap and rotor.
the older one prob 25-35 hours, maybe 15 on the other
Heres my original 2001 cap that came on the boat,
I also sprayed some corrosion stuff on the pick up that corrodes, That was a screw up, it wouldn't fire at all,had to clean it all back off, figure it was too much and would not carry the spark.trigger.
MSD wanted to see the caps, and rotors,They said the would warranty them,help having a buddy at MSD got new caps on, ran it a little sun am,seem ok, need to get out and run it hard see if its all back good
Attached Thumbnails MSD Dist cap center post Failing????-dist-2-001-2-.jpg   MSD Dist cap center post Failing????-dist-2-001.jpg   MSD Dist cap center post Failing????-dist-2-002-2-.jpg
MSD Dist cap center post Failing????-dist-2-004-2-.jpg   MSD Dist cap center post Failing????-dist-2-004.jpg   MSD Dist cap center post Failing????-dist-2-005.jpg
Strip Poker 388 is offline
Old 05-12-2014 | 06:25 PM
I've seen this on drag cars before....it was a poor engine ground that was found to be the culprit, after three weeks of chasing.
Jonesyfxr is offline
Old 07-02-2014 | 05:37 PM
Rob
Following up
MSD did say they have had some problems with the caps,he didnt say what,Im not sure if its all their caps or just the hei style, They did warranty them after sending them in, Pretty cool them standing behind their product.
Rob
Old 07-02-2014 | 08:31 PM
Wobble's Avatar
SORE MEMBER
Originally Posted by Strip Poker 388
Following up
Rob
msd went through a bad patch, this is an encouraging sign
Wobble is offline
Old 07-03-2014 | 12:33 AM
Rob
I would bet they had a suppler prob, Prob subing china, Im sure their feel the economy and are cutting cost.
I found a good replacement for the hei,it looks just like the msd dist half the cost, Im fixing swap out one see how it does
Old 07-03-2014 | 10:29 AM
Wobble's Avatar
SORE MEMBER
Summit has started making msd replacements for some marine apps. cap and rotor http://www.summitracing.com/parts/sum-g5223 http://www.summitracing.com/search?P...%20and%20rotor
appear to be to original spec and priced right
Wobble is offline
