Power steering cooler needed? >
Old 05-05-2014, 03:09 PM
vintage chromoly's Avatar
Default Power steering cooler needed?
Hello all.
Does anyone know if the power steering cooler is needed on a mayfair, twin cylinder, Saginaw pump, single big block setup. Boat is a 24-7.
If so, do I need the longer (big block) 12" one?
Thanks, rob
vintage chromoly is offline
Old 05-05-2014, 08:54 PM
My Fountain came with powersteering coolers on both engines. The originals are 2" dia x 9 inches long, a dual cool unit with oil cooler for the second tube.
It is my understanding that the powersteering coolers are necessary.
Wes Burmark is offline
Old 05-07-2014, 06:54 AM
yes, the long higher RPM's will cause the fluid to foam, also some say to use only the GM high performance P/S fluid, I use it in my Hardin setup..
ezstriper is offline
Old 05-07-2014, 08:10 AM
Thanks guys
Old 05-07-2014, 01:11 PM
Ive always used Dexron ATF. Never had any issues with steering for years. Should i have been using power steering fluid?
MILD THUNDER is offline
Old 05-07-2014, 01:54 PM
Ok, I have the old Saginaw pumps. Gonna keep rocking the ATF. One thing I've liked about ATF in my steering , trim, and tab pumps, if some spills or leaks, it cleans up easy, unlike normal oils and gear lube.
Old 05-07-2014, 05:33 PM
Received 4,326 Likes on 1,241 Posts
I`m not putting a power steering cooler back on this year, I had this little gay ass one that probably wasn`t doing jack anyway. Mild Blunders was leaking and we by passed that ***** and I don`t remember any negative effects. One less thing to worry about imop
I`m confused, one power steering pump, two coolers , one per motor?
ICDEDPPL is offline
Old 05-07-2014, 05:48 PM
Some boats have a P/S pump on each engine.
You are correct, we did bypass my cooler and I didnt see any negative effects from it. I have another cooler for it, I probably will install it though. The new cooler I have for it is like 2''X12" I believe. Latham recommends a 2x9" bundle, or 3x6'' bundle cooler for their steering systems.
