502 MAG not advancing >
Old 05-08-2014 | 11:37 AM
Tib
Default 502 MAG not advancing
Ok working on a 502 MAG with MEFI-3 ECM. After some motor work I set the base timing (with Mercury hand held) at 9*. The problem is i'm not getting any advance out of the distributer when rpm increases and I am thinking it is the Ignition Module in the distributer? I have ohm the coil inside the cap and it is good and the advance ring in the distributer is moving freely. I doubled check that it wasn't in "base timing mode" by unplugging the diagnostic tool. The new module is on the way and was wondering if I might be missing something?
Tib is offline
Old 05-08-2014 | 03:17 PM
Steve H's Avatar
artselectricinc.com
Coil in the cap? Advance ring?
I had a MEFI 1 system. It used the standard small cap GM distributor. The only moving part in it it was the shaft, and advance was controlled by the ECU.
Steve H is offline
Old 05-08-2014 | 08:50 PM
Tib
Ignition module was the fix!!!
Tib is offline
Old 05-09-2014 | 04:06 PM
Thanks for reporting back.
Cole2534 is offline
