Hardwall water hose
Are you talking about the suction hose going into the seawater pump? I just use standard band clamps, but I double them up on each end. Had a problem with air being sucked in on the transom assy connection one time. Extra clamp solved it.
Running all new water hose and bought hardwall hose which has a steel wire in it. Can't get a worm gear hose clamp tight enough to pinch it b4 the clamp strips out. Bought t-bolt clamps and they aren't getting the job done either..
