Carbureted 502 MAG Timing And Fuel Help Please!! >
Old 05-21-2014 | 09:40 AM
Default Carbureted 502 MAG Timing And Fuel Help Please!!
I am in the process of finishing the re-install of my 502 back into the boat.
I have seen several different viewpoints on how to set the the timing on these motors. I have also seen on this site that a lot of guys are running 87 octane in their 502's as well.
The question I have is where and how do I set the timing on this motor, and can I really run 87 in this thing without the chance of anything bad happening.
I have set the timing on our small block race car engines many times and I just want to know if there is any difference in procedure with the mercruiser thunderbolt ignition setup.
Any help would be greatly appreciated.
GoFast28 is offline
Old 05-21-2014 | 09:49 AM
Jump pin a to b on the dlc connector. Run engine at idle and set base timing to specified level, usually 8 degrees when warm. Remove jump pin, run engine in neutral over 3000 rpm and confirm timing is at specified number for total timing. Important that you check both.
4bus is offline
Old 05-21-2014 | 10:36 AM
Excellent! Thank you. Does anyone have any thoughts on the 87 octane?
GoFast28 is offline
Old 05-21-2014 | 10:51 AM
Rookie's Avatar
I believe they are designed to run on 87.
http://www.mercurymarine.com/service...?category=fuel
Rookie is offline
Old 05-21-2014 | 11:52 AM
SB
If it's a Tbolt IV there is nothing to jump.
SB is offline
Old 05-21-2014 | 01:23 PM
The boat is a 91 fountain fever. Will it be stamped anywhere whether or not it is a thunderbolt IV?
GoFast28 is offline
Old 05-21-2014 | 04:58 PM
I'm sorry, you are correct. I thought I read 502 mpi
4bus is offline
Old 05-22-2014 | 01:34 AM
If its a 1991, then its a TB IV. It should say so on the module also.
Griff is offline
