Here we go!  blew up a blower motor >
Old 05-23-2014, 05:35 PM
Originally Posted by MILD THUNDER
You're fine. I'd have no problem using that rod/bolt combo with 800HP all day. Your typical H beam rating for a BBC is
800HP with 8740 bolts
1200HP with ARP2000
1500HP with L19
I take that with a grain of salt though, because there are things like stroke, piston weight, rpm, that factor in. But generally speaking, for a N/A 496 Stroker, you have PLENTY of connecting rod with the 8740 bolt. However, if I was building a 1500HP engine, I wouldn't be using a eagle, scat, or compstar rod. I'd want some Carillos in there.
Manley has been providing H beam rods for many years. I believe they recently dropped the L19 option from their h beam rods. Now you can only get 8740 or, upgrade to the 2000 series. If you get their pro series rods, they come with arp2000 standard, and ARP Custom Age 625 as an option on certain bbc rods, such as the beefy marine duty I beam rod that cost 1500+ a set.
Thanks MT, I appreciate the input. Of course, I also have the limitation of a cast steel crank instead of forged, but this is far from a max effort build. If I had the whole thing to do over again, I certainly would have gone forged from the outset, but for what I will be doing with this motor, I should be fine.
Planning to hear it roar to life this weekend!
BTW, is that girl in your avitar surfing OSO?
Budman II is offline
Old 05-23-2014, 06:39 PM
Rookie's Avatar
Received 1,207 Likes on 580 Posts
Budman, am I putting things together right, that you are using Eagle cast stroker cranks?
Rookie is offline
Old 05-23-2014, 07:20 PM
I'm going to ask him about running a scat rotating assembly. Will my stock 8 at oil pan be ok? The only fuel I could get around me non ethanol is 90 octane. What compression should I stick with with those 049 heads
Trouble boy is offline
Old 05-23-2014, 09:21 PM
Stock pan and oil system good for a stock motor after that its time for some better parts.
Black Baja is offline
Old 05-23-2014, 10:45 PM
yep - single engine.
Old 05-24-2014, 05:31 AM
This is twin engine boat
Old 05-24-2014, 08:29 AM
Sorry TB, looks like I walked all over your post. Hopefully some of the info discussed with my build will be helpful for yours. If you are running a supercharged application where there could be more blowby to mess with oil drainback to the pan, along with a stroker crank, I would recommend upgrading to a 10 quart or larger pan. There is a lot of discussion on this forum about oiling systems, heads, cams, etc. There was a poster who goes by "ArcticFriends" who put together an epic thread about the ins and outs of properly setting up the oiling system for a high power marine engine. I would recommend searching for it. You als mentioned that you were talking to Bob M about cam design - he would also probably be a good guy to ask about other aspects of your build, like heads, valvetrain, etc. Good luck with it!
