Ocean Marine AC unit reading HPF???
Ran the heat in the boat about a month ago and it ran fine, ran the heat again over the weekend and fine again. Switched to AC and it ran fine for about 5 minutes and shut off. There was water flow with the heat, not sure with the cool. There is water in the lines past the pump and sea strainer, I can see that in the bilge. I try turning off the system and the breaker and I still get the HPF flash code and the system does not run. Could it be a sensor? And if so can it be replaced with out the freon leaking out. Need some help here.
Thanks!
Thanks!
High pressure from insufficient water flow or a bad switch. I`d lean towards water flow those switches don`t go bad that often.. but iM` speaking from commercial and residential experience only..
First I`d check water flow then I`d jump out the switch. Those units have a critical charge and I`m pretty sure you`ll lose the charge if you need to replace the switch.. meaning you`ll have to weight the charge back in ..meaning time for a professional
Assuming its a R/C vs electric heat unit sense you state water with heat. 5 min seems about right timing before it will overheat with no water flow. Make sure you have flow coming out, not just water in the lines. Do you have to press the reset to get it to run?
artselectricinc.com
I tore the thing apart today and no reset. I turned the AC unit on while the boat was out of the water and when I switched the thermostat to cool I got a click... then another click and the HPF flashed again. No fan running no compressor. I flipped it to heat and fan turned on. I located the HP switch and jiggled the wires around trying to locate how I could take it off or if it would release freon and after that I tried one last time and it kicked on. I quickly turned it off but I think that answers my question.
Also is Ocean Breeze the same thing as Ocean Marine??
