anyone running a 5 blade with 525 efi? >
Old 05-28-2014 | 11:24 PM
Default anyone running a 5 blade with 525 efi?
Advantages/disadvantages over stock 4 blade?
Thanks in advance.
imartin is offline
Old 05-29-2014 | 07:41 AM
Dave M's Avatar
Veteran: Navy
Yup, But I think the hull and setup is more of a variable than the motor.
I have a 2006 30 Superboat, 525efi, Bravo XR w/ITS. My everyday prop is a 26P maximus, right out of the box. I also run a labbed 28P bravo.
Lightly loaded, I am on the rev limiter (5400) with the bravo, the Maximus only gives me around 5000 RPM.
The bravo top end is several MPH faster, partially dues to the RPM difference.
The Maximus offers better cruise speeds and stays hooked up much better when planing, turning, and rough water.
They say 5 blades are harder on drives.
Dave M is offline
Old 05-29-2014 | 09:59 AM
Thanks Dave. How has that 525 treated you? Any header issues like folks talk about? Has maintenance been a bear? How many hours on her?
imartin is offline
Old 05-29-2014 | 10:36 AM
VoodooRob's Avatar
My boat came stock with 5 Blade Maximus 30P.
VoodooRob is offline
Old 05-29-2014 | 03:35 PM
Dave M's Avatar
Veteran: Navy
239 hrs to date, low maintenance. I replaced the headers with Stainless Marine at the beginning of the season. The shop pressure tested the CMI's after he took them off and said that did not leak.
Dave M is offline
Old 05-29-2014 | 03:40 PM
ah, good to hear! Im really considering a boat with the 525 so doing some homework. Some of these threads scare me! One guy mentioned he had the CMI mods/correction done which I just read entails removing that hose that connects the back to the tail and plugging the hole......
Great forum, thanks guys!!
imartin is offline
Old 05-29-2014 | 03:47 PM
Dave M's Avatar
Veteran: Navy
Yup, it was a Merc service bulletin about the hoses. If your looking at 2007 motors, it might of been corrected by then. Also, make sure you drain them while not in use.
Dave M is offline
Old 05-29-2014 | 09:27 PM
pulled up some old threads from 2011 where you, Dave M posted a pic of the pre mod rail with hose as well as a .pdf of the technical service bulletin! Invaluable!!!!!
Praying the 2007 was corrected, wont know till this weekend......
Thanks!
imartin is offline
