Dyno Day!  Question for engine builders - A/F correction factor for dry dyno headers? >
Old 05-30-2014 | 09:28 AM
Knot 4 Me's Avatar
Originally Posted by buck35
Great build!
Now you can worry about your bravo......
Congrats and happy boating! I
Lol! That's what I was thinking. Next thread from BUDMAN II, My Bravo Build!
Congrats!
Knot 4 Me is offline
Old 05-30-2014 | 09:52 AM
Congrats!
Man, I hope not. There's a reason I didn't go for a 540. I'm surprised there aren't more OSO guys on here rebuilding their own drives.
Budman II is offline
Old 05-30-2014 | 10:00 AM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
I know for a fact that the blower I bought from Mike is definitely scaring the living chit out of my B1 . Hopefully being a 1:36 diesel drive on a light cat will help .
the deep is offline
Old 05-30-2014 | 10:22 AM
Is the 1:36 ratio inherently stronger than a 1.5:1 ratio? I have a 1.36 in my Bravo. Next step is to figure out what prop I need. Had a 23 Mirage Plus for it, which roughly corresponds to a 25 on a 1.5 drive, but with these numbers I'm afraid I may have to step up to a 25.
Old 05-30-2014 | 10:28 AM
I think it was Mr. Gadgets who said the 1.36 gears were a little stronger because of their size
hadleycat is offline
the deep's Avatar
Fast Singles Club
I believe you will like what you read here . http://www.offshoreonly.com/forums/g...vs-1-36-a.html
the deep is offline
Old 05-30-2014 | 11:21 AM
Good read, deep - thanks for the link!
Old 05-30-2014 | 03:04 PM
Bud, you are probably going to need a 24 b1 should put you in the upper 70's with your boat and chine walk very nicely. Congrats on the motor sounds like a runner.
Black Baja is offline
Old 05-30-2014 | 04:03 PM
BB, I was thinking about trying one of those. Friend of mine has the identical hull to mine, 235 Force, and was running low 80's with a blown 502 a few years ago. He tried a 4-blade on his and found that it gave him too much stern lift and not enough bow lift, which is what these boats need. They have the helm and driver's seat pushed further forward than a lot of other go-fasts for more cockpit room. Also has fridge, head, etc in cabin, which makes them nose-heavy. He found that a 3-blade with a lot of cup helped to lift the bow and cut down on drag. My boat tends to be very nose-heavy. Always had a hard time lifting the bow with the 454 that was in there before. I have a 23 Mirage Plus that belongs to a friend that I am going to use as a starting point. I know it is probably not enough prop, but I want to see how it carries the bow. I will also be looking for a 25 three-blade and probably a Bravo 1 like you described to try.
At this point it will just be nice to have it moving without a paddle!
Old 05-30-2014 | 04:26 PM
Here are the sheets from the final dyno run. Fought my scanner all day before I gave up and just took pictures with my phone.
Sorry for the neck strain on the graph. I rotated it in the photo editor and saved it that way, but for some reason it has it sideways again.
