-   -   4 Blade vs 6 Blade. (https://www.offshoreonly.com/forums/general-q/313035-4-blade-vs-6-blade.html)
Mseuro 05-29-2014 11:36 PM
4 Blade vs 6 Blade.
I spun a prop last weekend and am thinking about getting a new set. I would like to hear about the benefits of a 6 blade setup. I now run Bravo 1 4 blades but would like a better hole shot and less vibration. I know it's hard to get my boats big atf out of the water and on plane but I was wondering if more blades would help, plus they look cool.
Running a Baja 405 with 496HO's top speed is 60 + or - at 5000 rpm Bravo 1 with 22 pitch
HyFive578 05-30-2014 06:56 AM
22 pitch seems low for your setup but admittedly, I'm not that familiar with the 496. 6 blade props are really only good for boats with high x-dimensions. If thats not the case with your boat, those 6-blades will be very hard on your drives and will probably not improve your planing performance. You might be better off with a hydro 5-blade or labbed maximus. Call Brett at BBlades... he can help you..
MILD THUNDER 05-30-2014 07:31 AM
I would not put a 6 blade on your setup. Might wanna call BBlades, and see about a 21 or 23 Revolution 4 blade. I had a heavy old 40FT Formula, and those were the best planing and best overall running props on that boat. Planed better than the bravo 1 4 blades and 5 blade maximus props. Might even gain you a touch of top speed. BBlades has a demo program.
Mseuro 05-30-2014 07:41 PM
Thanks will do
