Baffled by apparent reversion issues with Lightning headers and mild cam
#141
Ok ,so I have used the same headers with more cam...No problem. .Headers are not the problem with your build .You could just about have a gill type short riser exhaust on that cam and not have an issue. If it is truly sucking back hard, you did something wrong on motor..Did you degree the cam in.If so ,what timing set did you use ?........Never have I heard as much debate over a relatively mild build .......
Thought that running a 20* module and advancing the cam to 14* might help a little, but it's splitting hairs.
#142
Same headers ..what you are calling divorced collector ..I think they called them extended aft water when I bought them .Only difference in motors being rpm airgap intakes because they were on a 39' stinger. AFR 305 heads
#143
FWIW, my friend is running (I think) the same headers with an HP500 carb cam. Who knows?
You brought up a valid point that something timing related could cause it to revert, but I'm pretty sure it's put together right. Thanks for the input, motor.
#144
I know you gave cam specs, but who's cam ? as I stated in another thread you can change or "fool" the engine a lot by moving things around and still keeping the same lift/duration...example, you can add or remove compression with the cam design, now won't be computed figure like a 125cc dome with 130cc head, but ck with a compression gauge and can change a bunch...both ways
#145
Just as a hypothetical, what effect would advancing or retarding a cam have on reversion? SB, MT, others want to weigh in? Just curious.
#146
Merc Blue has their Crane Cams installed 5° advance in the HP500/500EFI/525EFI for a reason. Closes the exhaust valve sooner. A wider lobe seperation angle (LSA) closes the exhaust valve sooner also.
Remember, the exhaust valve is still closing After Top Dead Center (piston going down) on the intake stroke.
Atmospheric pressure doesn't care what valve is open, just as long as it's open. It tries to fill the growing void left by the piston going down. So...air/exhaust/water coming back thru the exhaust into the combustion chamber is exhaust reversion.
#147
#149
Ran it again, with one side having the regular tip with restricted top water holes, and the other side having the silent choice diverters with a 4" extension pipe cut at an angle to extend the dry part of the exhaust almost all the way to the butterfly. This allows most of the water to drain right down the Y-pipe, with a little bit going out the tips. Ran it and both sides were pretty wet. Damn. So I ran it with the seawater pump belt removed an no water coming out the exhaust. Held a thin piece of paper at the tip and observed it being shredded as it pulsed back and forth. Put my hand back there and it was sucking it back pretty hard. I had visions of "motor" yelling "told ya so". Then I had an idea, and almost on a whim, put both muffler tips with the salisbury flappers on there and ran it for about 45 seconds. Boom - both sides dry as a bone. Ran it again and pulled the headers - pipes still dry. Can it be something as simple as that? SB, your earlier quote about collector length versus primary length is going through my head. Or was it just a matter of the salisbury flappers dampening the back pulse?
#150
The flappers don't dampen the pulse per say, they try to stop it. Positive pressure opens them, there no pressure or negative pressure closes them.
Remember, they are there to close down when engine not running and/or wave hitting back trying to go into the pipes.
The closing isn't as quick as the reverse pulse, but they do help.
So, in this regard, ie: trying to close when 0 or negative pressure, I guess they do dampen...but more the return energy wave..as it's trying to be a one way valve of sorts.
What I mentioned earlier was about collectors dealing with energy waves. Exhaust physics show that as an energy wave 'hits' the atmosphere, there is a resultant opposite wave that shoots back.
Camshaft and exhaust designers try to make it so your exhaust valve is closed, or almost closed, when this happens. It appears exhaust is more important in this regard.
A wrong collector length can ruin your day.
Again, if your header collectors are 4" and the rest of your exhaust is 4", then the rest of the exhaust count's as part of the collector.
I'm at work and trying to get out of here, so excuse me if my typing and 'talking' or lacking. LOL.
