Lubricant for silicone exhaust hose? >
Old 06-15-2014 | 11:49 AM
Anti-freeze is a good lube for this also. Nothing will stay in there for future disassembly. You will just have to break the seal with a screwdriver or something and spray some kind of lube in there if it's hard to get apart. I run the blue silicone hose too. It's worth every penny. It's more flexible too to help take stress off the headers.
thirdchildhood is offline
Old 06-15-2014 | 09:53 PM
Post Don`t make a special trip
Use what you have at home:
ICDEDPPL is offline
Old 06-15-2014 | 10:24 PM
ICD, somehow I knew I could count on you to chime in with a post like this!
Since I live in the commonwealth, we use KY Jelly around these parts.
Budman II is offline
Old 06-15-2014 | 10:59 PM
i use ky on impellers..her its water soluble!..
FIXX is offline
Old 06-15-2014 | 11:00 PM
BUP
Couple of tricks to get hoses, bellows, boots and exhaust hose on and off. for installing use dish soap.& water mix or glycerin or water base KY this is also great for installing new impellers into its housing plus avoiding dry starts of all impellers,
also for installing and need a leak proof seal is use Merc perfect seal and install hoses . bellows, exhaust hose & boots before it drys - things will slide right on a lot easier plus help better for a leak proof seal. Aviation seal is basically the same stuff as perfect seal.
Also installation for really tight fits of hoses, bellows use Mercs power tune spray the area, things will slip on a lot easier plus good for removal as you apply it then .
Next is the grease that I mention Super Lube clear grease is the best stuff for both install and removal. website. www.super-lube.com
For removal of hoses, bellows, exhaust boots & exhaust hoses, a radiator hose pick of different lengths works great also a hair dryer set on medium or hot will help as well.
Removal and installing fuel line - on / off hose barbs use a spark plug boot puller tool - the one that looks somewhat like pliers with insulated tips. So much easier using this tool.
BUP is offline
Old 06-16-2014 | 06:28 AM
Thanks BUP - great info from someone with many years in the trade.
Old 06-16-2014 | 06:57 AM
Biggus's Avatar
I use vacuum grease on the rubber parts. Incredible for impellers.
Biggus is offline
