Alpha hit something no forward or reverse >
Old 06-18-2014 | 07:08 PM
Originally Posted by Mbam
Does it overheat?
mbam is asking cuz if it broke at top of shaft, water pump won't turn. boat will get hot quik. but if it will idle, shaft could be broke so it'll turn drive-pump at low power and slip as soon as you hit gas. another option is craigslist-ebay. there are lotsa alpha drives out there.
dereknkathy is offline
Old 06-20-2014 | 08:00 AM
fountain27ho496's Avatar
Up date. The plastic Piece inside prop was jacked. Had a spare everything is fine. When does worst case turn into best case. Thanks for the help everyone.
I have not had an alpha in a long time. Was not familiar with the parts.
fountain27ho496 is offline
Old 06-20-2014 | 08:22 AM
SB
Good to hear. We gave worst case after we where told solid hub. Oh well. He's back on the water.
Everyone wishes they where that lucky. LOL.
SB is offline
Old 06-20-2014 | 08:39 AM
That's good to hear. The part broke like it was supposed to and saved your drive!
thirdchildhood is offline
Old 06-20-2014 | 09:53 AM
Exactly, Its my buddies boat. Sold the Fountain and its my way out on the water. Different set up than I am used to.
Old 06-20-2014 | 04:22 PM
in most cases you have what you fear, what you hope, and what you expect. you rarely get away with what you hope for. good chit mon!!!
Old 06-20-2014 | 04:31 PM
SB
I agree. Furthermore we have Murphy's Law and what we call Gowdy Yourself. Gowdy can be replaced by 'Jinx.'
IE: If you assume/think it will be easy, it won't be because 'You just Gowdy'd Yourself." . Even if it should be easy.
You can sometimes, not all the time, reverse this by thinking/fearing the worst. So, I believe this is what happened to the OP. LOL. He was smart enough to think the worst, and thus why caught a break.
SB is offline
