Air Fuel ratio >
Air Fuel ratio
Air Fuel ratio
Old 07-24-2014 | 07:30 PM
  #31
I just couldn't wait till the off season to redo my efi system. I ordered the new Holley HP efi controller from Haxby. It is a self learning unit. Then I went ahead and ordered the 71 lb. Injectors from RC injection in California. I have already upgraded fuel lines, filter head, etc.
I think I should have a nice piece once I install these last few things.
Keep your eyes open for a couple of Boost referenced regulators soon to be listed in the Swap Shop!
Thanks for everyones help on this !!!!!
hadleycat is offline
Old 07-24-2014 | 08:01 PM
  #32
Give us feed back on how things went. I earnestly hope we steered you in the right direction.
Trash is offline
Old 07-31-2014 | 08:25 PM
  #33
Injectors arrived today. Looks like they should drop in no problem. I may have to do some minor Die grinding on #1 and #8 on the intake manifold because of the Injectors slightly larger diameter.
I really like the way Eddie Young mounts the electronics on a carbon fiber plate on the back of the motor. I wanted to do something like that with my Holley HP,but I am very limited on space back there so I am going to mount mine on the Port header where the stock ECU was mounted. I do not have any real carbon fiber on hand but do have plenty of 3/16 aluminum plate and carbon fiber replica "formica" so I am going to fab up a fake carbon fiber mount.
[ATTACH=CONFIG]527237[/ATTACH][ATTACH=CONFIG]527238[/ATTACH][ATTACH=CONFIG]527239[/ATTACH]
Attached Thumbnails Air Fuel ratio-img_2140.jpg   Air Fuel ratio-img_2149.jpg   Air Fuel ratio-img_2142.jpg
Old 07-31-2014 | 08:38 PM
  #34
[ATTACH=CONFIG]527240[/ATTACH][ATTACH=CONFIG]527241[/ATTACH][ATTACH=CONFIG]527242[/ATTACH]
Fuel pressure regulator mounted on its own "carbon fiber" plate.
I have been having great luck with this old Lightning header that I welded a bung into.
Also RC Injection flowed the injectors before shipping and included print out. I should be back on the water soon as my Holley HP system arrives.
Attached Thumbnails Air Fuel ratio-img_2155.jpg   Air Fuel ratio-img_2144.jpg   Air Fuel ratio-img_2160.jpg
Old 08-05-2014 | 02:15 PM
  #35
Holley HP arrived today. Time to get to work and get this thing back on the water.
Old 08-05-2014 | 04:04 PM
  #36
interested to see how user friendly that setup actually is..good luck Rob
ezstriper is offline
Old 08-05-2014 | 07:50 PM
  #37
Cool deal Hadley, good luck and im looking forward to hearing what the Holley efi is like.
TooLateVTEC is offline
Old 08-05-2014 | 09:37 PM
  #38
Thanks guys, Installed new injectors tonite and removed old wiring harness. Holley system looks pretty nice so far. Just started a bit of wiring.
Old 08-17-2014 | 11:21 AM
  #39
Took the boat out yesterday for the first run with the Holley HP system and larger 71 lb. injectors. Runs awesome!!
Datalogged the run and my A/F was spot on throughout the entire RPM range. Alex Haxby emailed me a base tune that worked awesome.
Install and set-up was very easy even for a Fuel Injection amateur like myself.
Thanks for everyones help and advice on this.[ATTACH=CONFIG]527993[/ATTACH][ATTACH=CONFIG]527994[/ATTACH][ATTACH=CONFIG]527995[/ATTACH]
Attached Thumbnails Air Fuel ratio-img_2174.jpg   Air Fuel ratio-img_2183.jpg   Air Fuel ratio-img_1905.jpg
Old 08-18-2014 | 01:45 PM
  #40
Awesome to hear, your carbon panel looks killer !
