Leakdown Test vs Compression Test?  Help with a used boat. >
Old 06-30-2014 | 01:04 PM
Without looking it up I think it should be around 175-180#'s ..If i'm wrong i'm sure someone will chime in soon
motor is offline
Old 06-30-2014 | 01:42 PM
Boat that size with the 4.3 should run 45 - 47 mph with a light load.
Budman II is offline
Old 06-30-2014 | 03:22 PM
Leak test is a percentage, your fine if 15% or less. The 4.3 is pretty durable I put 2500000 hard miles on one and checked it before I sold it and the numbers where nearly perfect almost no leakage and compression were all within 2% of each other.
ThisIsLivin is offline
Old 06-30-2014 | 03:24 PM
Rookie's Avatar
Originally Posted by ActiveFun
Thanks All. Does anyone know what numbers Im looking to hit with a Mercruiser 4.3?
Leak down test are a %.
http://www.carcraft.com/techarticles...akdown_tester/
Rookie is offline
Old 06-30-2014 | 10:58 PM
BUP
4.3 Merc listed the compression pressure 180 psi in late 80 & 90's service manuals. Late 90's and 2001 manuals, they Merc listed it as a min of 100 psi. Anyways for whatever its worth.
Also a leak down test is not 100% full proof. One example, I have seen some that shown around 8 to 12 % leakage and a compression test of 65 psi. Broken valve spring and when you put compressed air in the cylinder it helped push the valve tighter against the valve seat to help seal it. IMO both are important but not 100 % full proof.
The 4.3 / 262 CID is still not as relieable as a 5.7L 350. We see some valve problems from them and the carb intake manifold has it own drain plug to drain water out for winterization. Many people and shops miss that drain plug on the carb intake as it easily freeze breaks. Also very weak lifter valley more so on the port side will crack very easy from improper winterization.
The V-6 marine engines hate to be over reved if you do not have a rev limiter incorporated in the ignition system.
IMO I would not rule out a vacuum test for testing the internals of any motor. Marine MPI engines can have a tad lower vacuum reading of 15 hg or 16 hg even from a brand new motor - the reason is because of the IAC system incorporated in the intake. The old norm for a good motor at idle was 17 - 21 hg for a vacuum test and basically is the still norm for carb motors. .
Motor you are correct about the specs of 180 psi but as I said Merc changed it to a min of 100 psi for the current 4.3 's in their listings of the service manuals. the thing about compression testing is to have close to even #:s across the board and IMO 140 and up would be fine for a V-6. If I had to pick 2 test only, I probably would do a vacuum test or a leak down and a full blown lake test.
BUP is offline
Old 07-01-2014 | 06:29 AM
I was under the impression that the 4.3 was the same engine as the 5.7 with two less cylinders.
Old 07-01-2014 | 07:19 AM
Thanks all. Can someone simplify, am I looking for a result of 140 per cylinder? Or is the number in percentage form?
ActiveFun is offline
Old 07-01-2014 | 07:17 PM
They are having the test completed tomorrow. So is the final answer the leak down % should be 8-12%? Then its ok to buy the boat?
