Carb help
Engines were new last year. Has been like this since new. Been real busy and havnt had much time to get it dialed in. I think the air bleeds are my next step. Just looking for suggestions to try next weekend when I go back to the lake. As far as the vacumn goes both engines are the same. And they have a very aggressive idle. Engines make 620 ft lbs at 4800 and 608 hp. And hp keeps climbing to 6000. Engines are being run at 5300 -5500 rpm.
I'm having trouble keeping my engines running in gear . It is idiling at 1000 rpm out of gear and drops to 550 in gear. They are 540ci 600 hp 950 quick fuel carbs. 35 total timing with black bushing in dist for more initial timing. Makes 5 inches of vacumn at idle. I don't have experience tuning using the air bleed jets. I would like it to have another 100 rpm or so in gear for a stronger idle. It smells fat at idle but if I turn the idle screws in any more it doesn't idle at all in gear. The engines were dynoed and perform flawlessly everywhere else. Just looking for any suggestions on the weak idle in Gear. I have also drilled a .040 hole in each throttle blade that did help.
http://www.jegs.com/p/Holley/Holley-...36511/10002/-1
1st thing I would do is run the dist locked, set at 34 and you will notice a big improvement in idle quality, also I bet if you put a timing light on it when you put in gear you will see it fall even lower than you 17 initial and start moving around making it even worse...with a good gear drive starter should not be a issue starting, if you do you can run a MSD start retard but would try without it 1st..
