Any feedback on Venture aluminum trailers? specifically the tandem 5k axle 8725
I just bought a double axle version for my 2000 272 Baja, it flexes more vs a steel trailer and needed MUCH adjustment/modification to fit my boat as it was a more generic trailer than the Eagle built specificly for my boat but for 4000$ where can you get a new 8300 lb trailer with disc brakes, mag rims, d range 15" tires and torsion axles. Overall happy so far, Smitty
Smitty, which model did you get and what is the name of the dealer you used? I'm being quoted 5k w leaf springs, aluminum wheels and front target bunks
Upgrade to 16' wheels/tires. 15" forces you to pretty much stay with ST (special trailer) tires. 16" allows you to run LT tires which in many folks opinions, are better for trailers.
IF you have to with 15" wheels/tires, supply your own and go with Maxxis Trailer tires. They are the best on the market right now, and come in E-load range 15" tires. Your capacity may not call for them, but you can't have too much tire.
Also, upgrade to EoH brakes. YES, it's more expensive, but IT"S WORTH EVERY PENNY. The increased control and stopping ability is DRASTIC. Remember, surge brakes only work when you are going forward, AND when the truck/trailer are in a straight line. Going around a curve, and panic stop on the brakes? Guaranteed jack-knife; not to mention if the pavement was wet.
Personally, on that trailer above, I'd want 2 additional sets of flat 2x6 bunks. Those flat bunks as they are set right there are not target bunks. They are too far low and back. They will be completely underwater. and the boat will float over/around them. You COULD make those work if there was another cross-member, and they were 2 feet longer--further forward.
Also, I'd want another set of flat 2x6s between the main bunks at the back. Why? They will ensure that when you pull out of the water that the boat settles perfectly centered on the trailer.
All I'll say about them is that you get what you pay for.
