Silent Choice Exhaust not opening. >
Old 07-14-2014 | 10:51 AM
Default Silent Choice Exhaust not opening.
Hello,
I know this is a long shot, but I was hoping someone could help us. We have a 1999 Baja 272 and I'm assuming we have the Mercury Silent Choice exhaust, but I'm not 100% positive. The port side exhaust won't engage, thus leaving our exhaust in "quiet" mode. We can hear it click, but the exhaust won't open. Is this system air driven or electrical? Ive read that it could be a bad battery causing them not to engage or possibley the linkage is just in a bind? Is there anything I can use to lube the linkage, and get it to moving freely again? Could I possibly open them by hand and just leave them open? Are there any other suggestions you could possibly give us? I really appreciate all the information you could give us.
Thanks again!
racer60m is offline
Old 07-14-2014 | 11:29 AM
Do you have air tubing running to them or wiring to the actuators
buck35 is offline
Old 07-14-2014 | 11:48 AM
I'm pretty sure there are no airlines. I'll have to get better pictures once I get home. This is the only photo I have on my work pc.
[IMG][/IMG]
racer60m is offline
Old 07-14-2014 | 01:15 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
You have corsa exhaust. It's electric. Watch the 2 solenoids when someone flips the switch. May just be stuck and need freed up. More than likely they are spring return closed. You can open them by hand, but they will close back. Could wire them open. A little self testing and posting results will help
US1 Fountain is offline
Old 07-14-2014 | 01:30 PM
Ok, thanks for the clarification. I wasn't completely sure which ones we had. We're going to replace the old batteries with marine batteries and I'm going to re-trace all of the wiring. I will keep the post updated with all of the progress. Thanks again guys!
racer60m is offline
Old 07-21-2014 | 08:02 AM
Thanks for the info guys. It actually turned out to be a voltage problem. Replaced the batteries and the exhaust started working again.
racer60m is offline
Old 07-21-2014 | 09:35 AM
Before I could start typing I saw the voltage issue-- I've seen a number of posts that have said that exactly -- usually a low voltage and from what I've read these actuators are very voltage sensitive.
I love the Silent Choice Option. In my world- when activated it adds about 2-3 mph to WOT-- plus it sounds great
Safe Boating
3pointstar
3pointstar is offline
