Reversion possibility question on SBC with XM270HR cam
I had a 355 vortec truck motor in my Stinger (blew up the 383 in spectacular fashion). I ran a GM "Hot" cam with Z06 springs on the stock vortec heads. Reliable and powerful. If you have the vortec engine, go roller and this route. Proven 380-400 HP and rock solid.
Hello, I basically have a stock L31 (5.7 vortec truck motor) with aftermarket valve springs to handle a higher lift cam. Motor has a dual plane intake with a quadrajet carburetor and HEI ignition. Alpha drives.
I am wondering if a Comp Cams XM270HR cam would cause resonance reversion with the stock mercruiser manifolds and 4" mercruiser risers, standard through hull exhaust?
The next cam up, the 276, says it needs better exhaust. Wondering if this one is ok with the stock exhaust?
http://www.compcams.com/Company/CC/c...?csid=202&sb=2
Intake Duration at 050 inch Lift:218
Exhaust Duration at 050 inch Lift:224
Duration at 050 inch Lift:218 int./224 exh.
Advertised Intake Duration:270
Advertised Exhaust Duration:276
Advertised Duration:270 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.495 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.503 in.
Love seperation is 112
Intake centerline is 110
SB, Thanks for the bump and kind words! I must be getting old, I've had nightmares of leaving the VR1 stock lately! Or, at least until the 496 tires out....
