if i had water in bravo one fluid...
would it go to the bottom and i would see some come out when pulling bottom screw out? I had a leak in my outdrive top cap. Replaced the o rings and wanna check to see if water is i the fluid. Only have about one hour running time on the fluid that is in there now and dont wanna dump it if i dont have to.
Not sure if the specific gravity of gear lube is lower than water.
That said, I'd probably have a "come to Jesus" moment and dump it. |
The water will go to the lower end, always comes out first.
Mac |
Water will be at the bottom.
It's not worth the risk. Just drain and replace. $33 bucks and 30 minutes is a lot better than hoping and praying.
I just threw out $100 worth of perfectly good VR1 Racing oil and Lucas Treatment because it was too thick forced my oil pressure too high. |
I went through 40qts of engine oil, most of it royal purple xpr this week. After I refi my house to change the oil one more time I'll have piece of mind.
| All times are GMT -5. The time now is 01:24 PM. |
