Big Block Spark Plug Question? >
Old 08-24-2002 | 09:50 PM
Donzi22zx
Wink Big Block Spark Plug Question?
Wich is the better performance spark plug for a 454 mag EFI the AC Delco MR43T or the MR43TS. The MR43T is a standard nose plug and TS is a projectid tip. Please help. Also is the NGK V power a good performance plug.
Thanks Bill
Old 08-25-2002 | 10:15 AM
kaamacat's Avatar
Donzi22zx....One other plug you might want to try (which is like the MR43T) is the NGK-BR6FS. I've just put a set in on one of the engines (just by chance the place didnt have the others), and, I must say the NGK's are pretty darn good so far. I do not remember the motors starting up quite that fast before.
Bob
kaamacat is offline
Old 08-25-2002 | 11:16 PM
Bo Knows
Donzi
The MR43TS is definitely the performance plug to use. The farther you can get the tip of the spark plug into the combustion chamber the better. I've been using these plugs for 2 years now with no problems.
Bo
Old 08-26-2002 | 07:44 PM
I run the NGK R5673-9, stock #3442. My engine is a blown 509, 878 horsepower. Just ordered a new set from Summit.
Craig
mltdwn12 is offline
Old 08-26-2002 | 08:09 PM
obnoxus's Avatar
Charter Member #1171
Try an A/C Rapdi fire plug,,, part # 1
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 08-28-2002 | 07:58 PM
klmken's Avatar
What is the difference between the MR43ts and the R43ts? I'm sure M stands for marine but what exactly is the production difference?
Ken
klmken is offline
Old 08-28-2002 | 08:19 PM
DOCTOR DAVE
try the ngk race plugs i think the number for you to try would be r5674-7, i have used them for years. they really work well and are very reasonable in price under 2 bucks from lane automotive (motor state distributing) in michigan
Bo Knows
The M does stand for marine. Both plugs perform exactly the same but the marine version, which is always more expensive, has a rust proof metal case. I use the R43TS plugs and change them every year and don't have a problem with them rusting. I guess if you change plugs every 2 or 3 years you might want to use the marine plugs. It's no fun trying to get a broken plug out of a head. Sometimes the cylinder head has to be removed to do it.
Bo knows
C_Spray
4
02-18-2008 10:22 AM
Poorsche
0
06-15-2006 07:32 AM
Tantrum
07-16-2004 05:41 PM
Sydwayz
8
08-07-2002 05:10 PM
wwwTOPDJcom
2
05-23-2002 11:56 PM
