gen 4 gen 5 question >
Old 08-01-2014 | 07:51 AM
glassdave's Avatar
Neno the mind boggler
Default gen 4 gen 5 question
hey can I put a gen 5 454 mag efi system on a gen 4 engine? heads are rectangle 365 mags but may swich over to an aftermarket aluminum of some sort.
08 OPA High Points Champion
glassdave is offline
Old 08-01-2014 | 07:54 AM
heads can but its risky for water intrusion.efi will go on.
sutphen 30 is offline
Old 08-01-2014 | 07:55 AM
Yes you can, only prob may be mapping the ECM for the difference in vacuum at idle from the different cam profile. Try and get it set up with an mefi 4 ECM.
Unlimited jd is offline
Old 08-01-2014 | 01:21 PM
glassdave's Avatar
i have the proper cams and ECM's that were custom mapped by Tyler Crockett for this set up. I just wondered if technically there were any differences in intake/head mating faces or anything like that
Old 08-01-2014 | 02:41 PM
Nope your good to go there.
