how do you align an engine? >
Old 06-24-2017 | 10:07 AM
Anyone know the diameter of the transmission end of the alignment shaft? I think I have the aluminum plate that goes on the helmet, I also have a shaft but it's not fitting in the transmission well. I may have to make a shaft or an adapter. This is the speed master 3/4/5 application.
ezrizer is offline
Old 06-24-2017 | 11:21 AM
you may be able to measure diameter on the low side of the splines on the drive
outonsafari is offline
Old 06-25-2017 | 08:40 PM
transmission end diameter is just under 1-1/8", 1.110-1.115 should do it
ezrizer is offline
