oil spray from the front of a new 502 motor custom built
Isn't there a bolt that screws in the fromt of the block where the fuel pump pushrod is and goes clear through into that cavity
no electric and the way its wired is nuts they have the hot on the postive side of the oil pressure switch on that back of the block so once its see pressure it kicks on and builds about 12 psi there is no bypass on the fuel back o the tank not sure if the carb can hold back fuel so having it running when the motor is not is not a good idea plus if you loose oil pressure it will kill the full pump is that the idea behind this setup
It's a safety item to kill the pump with loss of oil psi. So, that part's fine.
Well, you may have inavertently told us why your engine is being washed down with fuel and why it doesn't like to idle at normal speeds.
And that is, the 12 psi fuel psi !
If there is no regulator before the carb reducing this psi, then here is your Golden Egg. Or, the one in sight anyway.
SORE MEMBER
1 Post
Wobble, Yup, that's exactly what I'm saying.
To everyone including OP:
Earlier in the thread he wrote that his oil smelled 'bad' of gas.
Then he wrote the oil looked horrible and they changed it.
Then later he wrote the engine wouldn't idle under 1100rpm.
We are on to something, and let the lesson be to others needing help that they need to include as much info as possible along with actually checking a lot of things and reporting findings...as this gentlemen did.
Too many people say something like "I have no oil psi, what do you think happened ?" or "My engine won't start..what do you think it is ?"
What is the best psi to run on the fuel system at the carb with out straving the motor when running at 2500 or better
is there a inline reg i can install to get the pressure correct
i been told by a shop that each gauge brand needs there own sending unit based on they the mfg makes there product boat has gaf rig in it is that true, if so we where given an off the shelf sending unit from a parts store that states they do marine work LOL
