aftermarket mechanical fuel pump >
Old 08-14-2014 | 07:46 PM
weldcrane's Avatar
cv products makes them real nice!!!!!
weldcrane is offline
Old 08-15-2014 | 08:51 AM
Are the specs the same between Airtex and Merc? I just replaced my pumps with Merc pumps earlier this season. The Airtex pumps say that they have been fitted with components compatible with multi-rich fuels. Just wondering if my new Merc pumps will survive with all the ethanol we're getting now.
Originally Posted by AllDodge
Nope, I just replaced both my mechanical fuel pumps on both boats with Airtex. Airtex makes the Merc pump it's just not painted black. Model 60932
http://www.airtexproducts.com/
ALL_IN! is offline
Old 08-15-2014 | 09:21 AM
Don't see an issue with the fuels, Merc doesn't make the fuel pump, Airtex makes it for them from what I have been able to determine. You use to see Airtex embossed on the side of the Merc pump years ago
Merc doesn't make a whole lot of things, like starters, fuel injectors, carbs, distributers, etc
AllDodge is offline
Old 08-15-2014 | 09:35 AM
MER Performance's Avatar
That's correct, have used plenty of them costly! but; 100 % rebuildable.
MER Performance is offline
Old 08-15-2014 | 01:07 PM
I understand that Merc doesn't make the pump. What I'm asking about are the specs.
ALL_IN! is offline
Old 08-15-2014 | 01:38 PM
Wobble's Avatar
SORE MEMBER
http://www.cpperformance.com/p-12460...6-engines.aspx
used this before works well
Wobble is offline
Old 08-15-2014 | 04:02 PM
Specs from http://www.airtexproducts.com/
UPC 080044140733
Type Mechanical
Inlet Size 1/4 in. -18 NPSF
Inlet Type Threaded
Outlet Size 1/4 in. -18 NPSF
Outlet Type Threaded
GPH (Free Flow) 40 GPH @ 1800 RPM
Max Pump PSI (Not System) 7.5-9
My buddy has one on his single engine 600SC Fountain and has never had an issue.
AllDodge is offline
Old 08-17-2014 | 09:56 AM
Like already said CV Products has "THE" pump, if you dont mind paying for it. I wouldnt trade mine for anything, work flawless, rebuildable, and awesome looking all billet construction.
Cobra100+ is offline
Old 08-17-2014 | 02:16 PM
I had the CV on my 557, flawless. Think it was model 2640 (?) And as MER mentions, they are rebuildable when/if that time comes.
Kidnova is offline
Old 08-18-2014 | 08:22 AM
Originally Posted by lil red
??? Like I said before take the 6 screws out and swap the lower halves. Done
You can replace the lower half, but the diaphragm and springs stay with the top half. The shaft that holds the diaphragm plate and springs in there looks to be riveted in place.
PowerAddict is offline
