Lower than I like Oil Pressure
Ive seen plenty of electric oil pressure gauges read far off from whats really going on. For example last year, my port oil pressure gauge was showing down around 25psi at idle in gear after a hard run, while the starboard showed like 40. I put a mechanical on the port engine, was actually about 45psi hot idle in gear. My chevy oil pumps have been shimmed. I see about 75-80psi warmed up and running at 4000RPM. Cold, getting on plane, gauges are nearly 100psi. On the dyno my engines had 100psi with no coolers, lines, remote filter, etc. Just had the filter on the block like a car would.
