-   -   jet size (https://www.offshoreonly.com/forums/general-q/316930-jet-size.html)
humpster 08-17-2014 07:58 PM
jet size
got 800 hp na motors with 1050 dominator carbs with no power valve wondering what jet size i should run to start testing motors so not to lean out motors made 810 at 6200 rpm
SB 08-17-2014 08:47 PM
What was the A/F ratio on the dyno with your current set-up ? Same carb's right ?
Griff 08-18-2014 01:53 AM
If you know they made 810hp 6200 on the dyno, what were they dyno'd with????????
ezstriper 08-18-2014 08:18 AM
I would put a 6.5 power valve in the primary to help idle quality...reduce the current primary jet by 8-10, assuming you are running same carbs dyno'd with
humpster 08-18-2014 05:38 PM
the boat had 10.250 :1 comp i dropped it down to 9.8 it come with 82 88 jets no power valve but that seems really low to me i didn't dyno the boat just have the sheets any thoughts???
BLUEMAGIC 08-18-2014 06:11 PM
These motors love fuel have 588s 1150 dominators work my jesse big no power valve either air fuel mixture screw out 2 3/4 turns idle in gear at 500 out of gear 1000 have to check what we have in for jets we changed out the idle air bleeds smaller make it idle u have these in the boat yet ??hole different animal from dyno lol
SB 08-18-2014 07:26 PM
82 and 88 without powervalves ?
Wholly schit !!!!
Somethings f*d up. That doesn't sound right at all. It's like having jets in the 70's with Powervalves. Do not tune in the boat ! Yet !
Get the list# off the carb and someone will look up what the carb specs where when stock.
skydog 08-19-2014 11:14 AM
Install wide band and set her right up....
Griff 08-19-2014 12:09 PM
If I had to start somewhere, I'd add a 4.5-6.5 PV to the primaries and increase the secondries to around 92's
Do the old dyno sheets have any AF's or EGT's???
MILD THUNDER 08-19-2014 06:49 PM
Dominators love big jets.
As far as the power valve, and idle quality, I see no relation. The powervalve simply introduces more fuel, into the main well. Whether the power valve is open, or closed, it should not effect idle quality. If the powervalve is ruptured, than yes, it will pull fuel thru the diaphram. Think about it for a second. If a powervalve adds lets say 8 jet sizes, so you plug them and jet up 8 sizes. Would your engine idle any different if you went from 82 jets to 90 jets? The sole purpose for a powervalve is to provide extra enrichment, at high throttle opening/high load.
