Thunderbolt Distributor Rotor - Stuck! >
Old 08-26-2002 | 03:27 PM
Default Thunderbolt Distributor Rotor - Stuck!
I was changing the plugs, wires, rotor and cap yesterday. Just some overdue maintenance. All was going well until I got to the rotor! The thing was stuck on there and would not budge. I pulled with my fingers and pliers. I pried with assorted tools not designed for the task.
A friend finally helped me out by having a dremil tool handy. It still took a great deal of prying / pulling. The rotor appeared slightly rusted / glued in place!
First -
Is there any easy way to pull these off? Has anyone developed a puller? Should I just plan on cutting them all off?
Second -
Why was it glued? Should I glue the replacement? What should I use? It seems like it is on there pretty good without any adhesive. (maybe I should have greased it?)
All input is appreciated. I have two more of these to do.
Thanks!
Steve
stevel is offline
Old 08-26-2002 | 03:38 PM
olysan
I think that it's standard procedure to use locktite when those are installed. You can break the bond with heat.
Old 08-26-2002 | 04:09 PM
Official OSO boat whore
Cold chisel and a hammer works wonders. Turned out that mine was rusted. After some emery cloth the new one slid right on.
Cord is offline
Old 08-26-2002 | 04:29 PM
Mbam's Avatar
Offshoreonly Advertiser
Shop manual calls for heat, 2 screwdrivers on opposite sides will do wonders, Loctite on the new one as this is what controls your timing. Any movement is BAD!
Mbam is offline
Old 08-26-2002 | 07:07 PM
BAD-HABIT's Avatar
So are you guys saying I should use loc-tite to put my rotor on....And the manual states this.... Ive never heard of such a thing. Are the rotors made with that much clearance??
"Bad-Habit"
BAD-HABIT is offline
Old 08-26-2002 | 07:52 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
"Bad-Habit"
Yep, as crazy as it sounds. Don't think it is a loose clearance issue, as a keep it "good-n-tight" thing
US1 Fountain is offline
Old 08-26-2002 | 08:12 PM
BAD-HABIT's Avatar
You don't say.....Well you learn something everyday....Thanks
"Bad-Habit"
Old 08-26-2002 | 08:37 PM
man o man i gota give out all my tricks....chanel locks....just twist it right off up and around in one motion....it breaks the tab clean off in the shaft....if it's worth changing then it goes in the trash....i don't use old stuff for back ups. i buy new for that.
audacity is offline
Old 08-27-2002 | 08:20 AM
I twisted pretty hard but I was afraid of damaging the distributor gear or shearing the little pin / screw that holds the gear on.
Thanks for the good tip!
Mark - Thanks for your advice. I pried all day with screwdrivers and that thing was not budging. ( I did not used heat) I purchased the parts from you. Great Website!.
Steve
stevel is offline
Old 08-27-2002 | 08:34 AM
the plastic will give way prior to the pin...i never said it was easy...that's way i said chanel locks ....i've done a TON of 500 hp's this way...may take some smashing prior to twisting..good luck.
audacity is offline
