A little roots blower info. >
Old 08-30-2014 | 08:58 AM
Default A little roots blower info.
Thought I would share this with my roots blower friends. I've always preached about how you shouldnt under carb a roots blower setup.
Last weekend, I was running my boat. I noticed my starboard engine, was only hitting 5lbs. (always at 6lbs). I starting thinking the blower was tired or hurt. I got back to the dock, and started looking around. Turned out while I changed jets prior to the weekend, I had pinched the secondary accelerator pump linkage on one carb, and it was keeping the secondarys on ONE carb from opening (twin 850's per engine). So, my one engine, was really working of 6 barrels instead of all 8, or lets say instead of 1700CFM, I had 1275cfm of airflow. That was enough to make my engine down on power from 3500-5500RPM. These are 468 engines, not 598's either. 420 blowers 7% underdriven.
I'd like to think, IF my engines had single 1050 carbs atop, I would have to spin the blower much harder (pulley down), to get to 6lbs of boost. Which in turn, would heat up the air charge. Something to think about if you're running that single carb atop of your roots blown big block. I think many look at twin carbs, like twin fuel dumpers. But, twin carbs, doesnt always equal more fuel consumption, but it does mean double the airflow capability.
MILD THUNDER is offline
Old 08-30-2014 | 11:23 AM
waybomb's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
850 cfm is measured at what pressure under the carbs?
waybomb is offline
Old 08-31-2014 | 07:47 AM
[QUOTE1 ½ inches of mercury ][/QUOTE]
http://www.thecarburetorshop.com/Car...izesandCFM.htm
Michael S is offline
Old 08-31-2014 | 07:59 AM
SB
Most single engine single carb N/A boats won't plane if the secondaries don't open. I've shown many people this that didn't agree when talking about it.
SB is offline
Old 09-03-2014 | 08:58 AM
Any interest in discussing intake air temperatures with their setups? Or, should i ask, is anyone running IAT gauges in their intake manifolds?
Old 09-03-2014 | 11:14 PM
Strip Poker 388's Avatar
Rob
i dont think you can over carb,im running 2 1050 on a 355 sbc
[ATTACH=CONFIG]528738[/ATTACH]
Strip Poker 388 is offline
Old 09-03-2014 | 11:21 PM
very nice,,you run that at the track.yet
sutphen 30 is offline
Old 09-03-2014 | 11:53 PM
Rob
Thanks Bill,Naw just got it running,5 miles, POS Magno at Nutech fuzked me on a NEW snout, seal had lip missing,puking oil out front,miss matched bearings,one seized,and shaft looks used,harwood hood came in busted,to much boost,never ending bs,Im calling it ZoomZoomBoom
Old 09-04-2014 | 08:28 AM
damn,i feel for you.can't wait to hear how it runs.
