Need help with engine issue >
Old 08-31-2014 | 07:56 PM
Do u know of the reason why it cracked? Due to hot, cold, age, etc...
HDMF is offline
Old 08-31-2014 | 07:58 PM
Do u why it cracked? Hot, cold, age, etc....
HDMF is offline
Old 09-01-2014 | 02:52 PM
For it to be pressuring up the coolant it has to be leaking from the combustion area.
You say the head gaskets look good so it is either a cracked head or cylinder wall.
Pull the plugs and look for moisture or rust on one (or more), and that will tell you which cylinders to scrutinize.
My guess is a cracked head between the valve seats.
Running hot will do it.
Cajun 2 Stepp is offline
