-   -   525efi rev limiter (https://www.offshoreonly.com/forums/general-q/317975-525efi-rev-limiter.html)
fastlane40 09-14-2014 01:13 AM
525efi rev limiter
Can anyone tell me when the 525 is on the hard limiter of 5400 what change in exhaust note is there?
Any backfiring or popping?
Griff 09-14-2014 02:38 AM
It will feel like an engine miss/stumble. It shouldn't pop or backfire
thirdchildhood 09-14-2014 05:32 AM
I get an early warning of a steady buzzing from the warning buzzer.
fastlane40 09-14-2014 05:56 AM
So a 525 should not have a crack or exhaust note that is easily noticeable when on the rev limiter with open/dry exhaust?
BUP 09-14-2014 12:12 PM
Run a scan of the engine. It will show up as an overspeed code and how many times it has happened. I would not keep bumping the engine off the rev limiter.
That is correct about hitting the rev limiter as it should feel like a miss / stumble Kind of like somewhat of an ignition component breaking up, then clears up when rpms are lowered.
Bawana 09-14-2014 06:33 PM
Oh yes you can hear it in the exhaust , when you stay in it on the rev limiter
fastlane40 09-15-2014 05:31 AM
Okay so its normal to hear missing in the exhaust note.I do not think mine are noticeable at all but one of my competitors
is extremely cracking and popping.
Bawana 09-15-2014 01:22 PM
Normal? No. It will do that if you stay hard in the limiter, I don't think its good on the motor at any time to limit cylinders for any length of time. That is why merc has the audio alert that happens first, then if you stay in it it will crack & pop.
fastlane40 09-15-2014 03:07 PM
Thanks for clearing it up.That will be the difference.I don't stay on it.
