Mefi 1 to mefi 3 question
I found a couple posts on this but couldn't find an answer. I currently have an efi 502 with mefi 1. I have a mefi 3 harness and a tuned mefi 3 ECM. Can the mefi 3 harness and ECM just be swapped or will I have to change anything? Thanks.
You have an MPI harness it is different than the EFI , as long as the mefi 3 harness is from a MPI motor and not a 500 EFI I believe you can just swap it out, as long as the connector's are the same, and the engine harness will connect to it.
The ecu I know is from an efi 502. If the harness plus into the ecu do you think it would work with everything else?
The mefi 3 harness does plug into the mefi 3 ECM from an efi/mpi 502.
easy to tell the difference, with the 502 MPI harness the ecm connectors set in the middle right side of the intake manifold, on the 500 EFI the connectors mount on a metal plate bolted to the back of the head on the same side, good luck
The motor will be coming out soon so if I have to put the new harness on I'll just wait.
Here is my new question. The mefi 3 ECU plugs into my harness that is currently on the boat. Does this mean it will work?
I did not get it on today. I spoke with Eddie (really nice guy) at young performance and at least on connector needs to be spliced in from the mefi 1 harness. A few of them will likely need to be extended too. Seems like a job for when the motor is out.
