Question On Coated Pistons
Did they offer a big bore cylinder from Millennium ? When you run the cast iron sleeve, the clearance is going to be greater than the aluminium that is nikasil plated, that defeats the purpose of the design of all the newer 4 stroke higher rpm single cylinder engines. What is the redline on that machine? Of course that's the X design piston from CP, which gives it strength. Did you increase the CR also. Does that cylinder head come with titanium valves as the YZ250F and the YZ450F do?
http://www.jegs.com/p/Total-Seal/Tot...50299/10002/-1
