New Merc 540 replacement engine >
Old 09-25-2014 | 07:39 AM
MER Performance's Avatar
I'm really curious; to see what the cranks, rods and pistons are. Stamped steel rocker arms and remand cast iron heads? 800 cfm carb, that would explain; 4500-4800 rpms. What is impressive about less than 1 hp per cid and 560 lbs torque for 15k-18k per engine, using Thunderbolt V with knock protection? Doesn't it seem strange Mercruiser, would now offer a engine with a carb and old ignition system after everything they have produced using EFI ?
For the same money, you could stroke you 502, alum heads, have good rocker arms, and install a 2000 cfm TB, install a Holley HP EFI, easily push 700 HP and 700 lbs torque, all with a hydraulic roller.
Just my engine builder 2 cents worth !!!!
MER Performance is offline
Old 09-25-2014 | 07:40 AM
Knot 4 Me's Avatar
Stump puller. I think they are targeting your 60's - 70's Caddy!
Knot 4 Me is offline
Old 09-25-2014 | 08:55 AM
The answer is simple... Its a 540, with a decent cam and intake/fuel injection it would make over 520 hp. They already sell a fancy 520 for more $$
With a bunch of torque and a 4600 redline its the perfect motor... for you searay...
phragle is offline
Old 09-25-2014 | 08:57 AM
I probably should have posted this in general boating discussions, but I thought being engine related information in might fit in better here.
johnny b good is offline
Old 09-25-2014 | 09:10 AM
eddie's Avatar
Originally Posted by Black Baja
What kind of crank and rods? Might be a good candidate for a blower...
It is, all good stuff. I asked at a conference earlier this year when it was announced.
eddie is offline
Old 09-25-2014 | 09:59 AM
Just did exactly that except with dominators for around $15k x 2. Wish I'd went EFI though.
payuppsucker is offline
Old 09-26-2014 | 09:45 PM
Exactly what I think!! I'm big into the small block side of boating and when the 400 hp scorpion came out I though it was a nice piece till I saw the price tag!!!
So2fast5u is offline
Old 09-28-2014 | 10:44 AM
Rebuild your tired 502 for half the price
Pismo10 is offline
Old 09-28-2014 | 12:56 PM
Get a ZZ502 - not much to convert to marine use.
Wannabe
wannabe is offline
Old 09-29-2014 | 06:53 AM
Full Force's Avatar
My 540's are .030 over (548CI) with extremely mild cams and aluminum heads made cob=coservative 600 hp 660TQ, how can any 540 be only 440 hp? even with stock iron heads would have to make 550 plus and still be reliable.
Full Force is offline
