Twin engine boat porposing problem >
Old 09-26-2014, 05:50 AM
Originally Posted by Griff
Caused by the boat not being able to carry the bow at that speed. It may be correctable with some prop tweaks or a prop style change.
The boat has full weekender cabin.
I did not want to say that it is a Checkmate 283 Convincor. I thought I would hear that all checkmates do the "Checkmate hop" which is mostly 251/253's and not get any good suggestions.
Old Navy is offline
Old 09-26-2014, 06:15 AM
never really heard of that at that speed, but sounds like the props are wrong...maybe has hydromotives which are a stern lifting prop vs bravo 1's which are bow lifting ??? would think prop/trim changes would take care of that..
ezstriper is offline
Old 09-26-2014, 08:11 AM
as Kieth, Griff and ez have stated, try changing your prop set up. Get with a prop guy as things change with a nose cone also.
liquidlounge is offline
Old 09-26-2014, 11:39 AM
Received 1,826 Likes on 911 Posts
Keytime has a twin bbc 283 Checkmate. I think with 454 or 502 mags.
Griff is offline
Old 09-26-2014, 08:21 PM
Before touching props or spending money, i think i would experiment with switching the props rotation.
MILD THUNDER is offline
Old 09-26-2014, 09:08 PM
Rookie's Avatar
Received 1,212 Likes on 583 Posts
My straight bottom boat porpoised when... 1. I ran the drives spinning in, 2. no hydraulic steering, 3. Hydrmotives. 3 blade Mirages changed the attitude the best. Also Spinelli's. I have a plethora of Props Spinelli's, Bravo1's, and Mirages if you need to try before you buy.
Rookie is offline
Old 09-27-2014, 07:26 AM
Thanks Rookie. I sent the owner a message regarding what props are on it and what direction they spin. His reply:
They are 26p labbed Mach 1s. Small pitch due to the 1.36 drives. They spin out.
Old Navy is offline
Old 09-27-2014, 08:24 AM
1 forget about the old owner. What he has to tell you may send you in the wrong direction. 2 What props are on it?
Blueabyss is offline
Old 09-27-2014, 08:53 AM
The props are Mach props. I think they are called "Stern Drivers" A lot of Checkmates came with these, they were round ear props. I think Reggie bought the company and shut it down after a while.
Old Navy is offline
Old 09-27-2014, 09:45 PM
ON, Mach props were made by Second Effort/ Gary Garbrecht. Gary ran Mercury Racing for a lot of years.
X-Driver is offline
