Another Engine Dynoed today. >
Old 10-04-2014 | 06:50 AM
  #51
Have you seen what mercury uses??? If they get away with those, there's more in proper machining than anything else.
Unlimited jd is offline
Old 10-04-2014 | 08:05 AM
  #52
Craney's Avatar
Originally Posted by mike tkach
that,s me driving my cat at 120 plus mph.that was several years ago and i built the engines[950 hp 540s] but they were not dyno tested at borowski,s.at that time they were owned by someone else and although i was working there as an engine assembler i was not happy with what was going on in the dyno room so i used a different dyno facility.the problem i had was not with the dyno equipment but the dyno operator was a lazy idiot.
The guy sitting next to you looks like he's $hitting has pants!!
Craney is offline
Old 10-04-2014 | 08:15 AM
  #53
i told him he needed sun glasses but he said he would be ok without them.i dont think he was enjoying his first ride at 120 plus.lol.
mike tkach is offline
Old 10-04-2014 | 08:20 AM
  #54
Cool. Good job guys.
So this crew of 4 geniuses couldn't make a centrifugal blower work?
hogie roll is offline
Old 10-04-2014 | 08:30 AM
  #55
no geniusis here,the centrifugal blower worked fine at a reasonable boost leval[12lbs] but not so good at 15 lbs on pump gas.the boat owner wanted more than physics will allow.you can not put a drag strip tuneup in a marine engine and expect it to live.hope this answered your question.
  #56
Oh it could have worked. But our buddy was not willing to reduce the boost level, to a reasonable PSI, for it to live. This was a carbed M4 application, that did make well over 1000HP on the dyno.
However, in the boat, it was less than stellar. Belt issues, bracket flex, blower getting so got you could fry eggs on it, lack of low end power getting on plane with a 42ft boat, and overall, it just wasnt a good combination as far as the static compression/cam combo he had. It was more suited to a roots than a centrifugal.
There is no doubt the prochargers work great when bolted on a stock EFI merc, running low boost. But imo, once you start getting up there with power levels, the whole thing takes a turn, and really needs to be thought out. And EFI is for sure the way to go there.
MILD THUNDER is offline
Old 10-04-2014 | 08:45 AM
  #57
[QUOTE=MILD THUNDER;4197298And EFI is for sure the way to go there.[/QUOTE]
and even then its a biotch to tune.especially if it has to run in open loop all the time.
they still make me cringe when asked to tune one.
sutphen 30 is offline
Old 10-05-2014 | 09:44 AM
  #58
Payton's Avatar
Charter Member #927
Nice job guys, cool thread.
Payton is offline
Old 10-05-2014 | 02:22 PM
  #59
Originally Posted by MILD THUNDER
I loved following budmans 489 build, even though it took several years, he still posted results. Without results, its kinda just a bunch of guys trading theories all day. :
Could you or budman provide me a link to that build?
In my search I only found a thread for the intake manifold on it.
See ya,
Kelly
huskyrider is offline
Old 10-05-2014 | 03:01 PM
  #60
SB
Kelly, it's about 150yrs long. Are you sure you want to read it ? LOL.
SB is offline
