-   -   Oil temp problem in my 572, need input/advice.... (https://www.offshoreonly.com/forums/general-q/318772-oil-temp-problem-my-572-need-input-advice.html)
I'CE 10-07-2014 12:46 AM
Originally Posted by mike tkach (Post 4198707)
i might be wrong but i think the bulldog pan is a 10 qt unit.2 xtra qts will cause oil foaming.
True an over full crank case in any engine will get aerated and foam due to interference with the recp. assembly. A problem none the less. but maybe not his re: high oil temps. 20w-50 v-twin Mobil is a good example of a stout product that stands up well in our marine conditions.
Borgie 10-07-2014 12:53 AM
Yes actually oil aeration can cause a spike in oil temps. Very common issue in racing!
Black Baja 10-07-2014 05:54 AM
Just an FYI. I've been running vr1 40wt in my motor all summer. Needed to do an oil change and got a heck of a deal from an OSO member on 20w50 Bradd Penn. I have a 16qt system so an oil change can be pricey that's why I bought the Bradd Penn. Went from 60 to 70psi at idle and 75 to 90 at WOT. Oil pan temp went from 250 WOT to 220. I wouldn't believe it unless I seen it with my own eyes. Deal or no deal I think I know what oil ill be using from now on. And the nice thing with the green oil is I can actually read the dipstick.
MILD THUNDER 10-07-2014 06:42 AM
I think we are stroking ourselves until we get some true temp readings at wide open throttle. This is when his oil pressure issue happens. Temperature can have a direct impact on the oil pressure. Most BBC engines Ive seen, hold a pretty consistant oil pressure from 3000-6000RPM, when the temperature is steady. When my oil is 120*, and i get up on plane at 3000RPM, my oil pressure is in the 90's. Once it gets up to 190-200 degrees, its in the 70's at 3000 and 5500rpm. If you are getting say, 250* at wot, I can see it losing some oil pressure, compared to what it is at 185*.
The stock oil cooler is probably a 2x17 or 2x21 case. On a 700HP engine, I'd be running a 3x18 style cooler. A stock 2x17 cooler, is ok for a 400-500HP engine. At cruise speeds, you are well within the limits of the cooler, at wot, probably not so much.
Also, the stock fittings merc used on those cooler applications, suck as far as oil flow. The idea of an oil thermostat is to help maintain a steady oil temperature in all conditions. In our cars, we run say a 195* stat. We see 195* on our temp gauge. Now, remove the stock radiator on your tow rig, and install a radiator from a honda civic. I dont care what temp thermostat you install, its gonna exceed 195* temp.
Dean Ferry 10-08-2014 07:22 AM
1 Attachment(s)
Thanks guys for all the input. Here is my plan of attack:
1. I bought some Kendall (13 qts.) GT1 20-50 Wt oil and will use a Merc racing oil filter to change to after the Oil Thermostat change out.
2. I will go Mystic and pick up my new oil thremostat and sender for install this week
3. I confirmed with "Chris" Merc. Racing yesterday, (Nice guy by the way, we talked about 15 minutes about my oil issue) that I do in fact have a 12 Qt oil pan. There is a misprint in the Merc racing HP500 BD owners manual that I have that states its a 9 qt oil pan. I have attached a pic.of oil pan
4. I do have standard HP500 bulldog oil cooler that is 2x17"
5. I'm thinking about relocating my Oil temp sendor to the Oil pan, you can see in the pic of the 2nd boss available in the pan for that install. The other 1 is used for my oil drain hose.
6. Ensure that my Oil thremostat pad has a good ground.
ICDEDPPL 10-08-2014 08:21 AM
Besides the oil gauge not working I don`t see any issues with the readings you posted.
Oil pressure is good.
Oil temp at 185* is fine
Drops when running hard= normal (oil heats up, gets thinner , oil pressure drops, mine drops to 50psi)
Drops after hard run @ idle =normal (mines drops to 20psi after a hard run with spring oilers)
Goes back up with some throttle= normal
You have 85* at the cooler.. unless the water you boat in is that temp looks like oil is running thru the cooler.
So besides the gauge I dont see what you`re worried about.
To test mine I take the sender out and drop it in some boiling water along with a thermometer and check against the gauge.( use an alligator clip to ground it)
racinfever 10-08-2014 10:12 PM
+++1
MILD THUNDER 10-08-2014 10:43 PM
I think the concern is the fact the oil pressure is dropping while being at wide open throttle, along with unknown temps at wide open throttle. I agree 185 is just fine at cruise. Ive seen boats cruise with oil temps that were just fine. However at full kill almost bury the oil temp gauge at 300 degrees at full throttle thanks to a lean tune up and the pistons glowing red. Few seconds later a rod cap let go and put a rod thru the oil pan on this particular setup.
If im running along at 4000rpm with my oil temp gauge showing 190, and oil pressure at say 70psi, when i nail it to 5600rpm for a few miles, oil temp goes to 210, oil pressure stays at 70psi or better. I personally do not want to see my oil pressure drop when i advance the throttles to a higher rpm. A properly setup oil system should not lose pressure as rpm increases. Just my opinion. At 5500rpm, you should have the same, if not more pressure than you do at 4000rpm.
airjunky 10-08-2014 11:09 PM
Pic was off but the orig 500 bulldog pan baffle set up was hard core . When merc charges 2k just for a cast pan I like to feel every inch nook and cranny . With the large lines right bypass valves in block orig cooler I've seen them support major boosted hp . Long shot and outside the box but maybe something in the cooler ? You running a sea strainer ? Those tall decks dont like dist seal issues down by the lifter galley area but yea be weary of foaming ,maybe run a t from your sender , and get ready for science .
ICDEDPPL 10-08-2014 11:16 PM
Not every one has your machine work and assembly workmanship Mild Thunder!
Im still surprised your oil pressure don`t drop a bit as the oil gets hotter/thinnner.
