Oil temp problem in my 572, need input/advice....
#41
My operating range is 180-210 on my oil temps. Nothing fancy about my oil system. Stock chevy pumps that mike tkach shimmed for me, proper sized remote oil lines, no hokey restrictive fittings, merc racing thermostatic oil filter heads, canton oil pan with windage tray and trap doors, and a plate cooler.
Before mike and i redid the engines, and shimmed the pumps, i had about 50-60psi at cruise, with pressure dropping to 40-50psi at wot. It wasnt a temp issue, as my temps were good. Only think i can think of was it being all the restricive 90* fittings used in the remote system.
#42
Don`t lie to me!!!
If im running along at 4000rpm with my oil temp gauge showing 190, and oil pressure at say 70psi, when i nail it to 5600rpm for a few miles, oil temp goes to 210, oil pressure stays at 70psi or better
#43
#46
Changed the oil to Kendall GT-1 20-50 WT racing oil with ZDDP. Going to test today. And I only dumped in 11 qts, oil is showing "ADD" mark on the dip stick. I'll have the 12th qt with me
Thanks,
Dean
Everything is for sale @ a certain $$
#47
The new oil temp sendor that I ordered IS different that the 1 that was in there so I changed that out.
Thanks,
Dean
#48
If you r going the Walmart oil route I recommend 2 cap fills of head and shoulders for the zinc additive and it will help keep the crankcase clean...
#50
Good luck with the testing today! Wish i was on the water today
