Stainless marine gen 3 gaskets >
Old 10-07-2014 | 08:15 PM
Default Stainless marine gen 3 gaskets
What gaskets are they ?? Any of these:
http://www.summitracing.com/parts/mrg-5913
http://www.summitracing.com/parts/mrg-5910
ICDEDPPL is offline
Old 10-07-2014 | 08:23 PM
I'm just gonna tell you what has worked extremely well for me and my gen iii's for about 40 hrs with no leaks is a very very small bead of copper high temp rtv... I figure if you have two machined surfaces why do you need a gasket? Little different using Stainless Marine manifold than thoose cheesy CMI headers... :-)
Black Baja is offline
Old 10-08-2014 | 08:04 AM
They`re used and sealing surface not the greatest..
ICDEDPPL is offline
Old 10-08-2014 | 09:22 AM
dan,if you use a gasget sealer i recomend the right stuff,it is a million times better than rtv.ok maybe not a million but much better.if the serfaces are not flat borowski,s can resurface them,you dont want any exhaust leeks!
mike tkach is offline
Old 10-08-2014 | 09:51 AM
I agree it is some killer stuff. Only reason I used the rtv was cause the temp was a "little better".
Old 10-08-2014 | 09:56 AM
If you call stainless marine they do sell gaskets for their manifolds 2...
Old 10-09-2014 | 08:02 AM
All I use...work great...I do use the red RTV on them as well as I don't ck header bolts as often as I should...
ezstriper is offline
