Roots Blower Sizing >
Roots Blower Sizing
Roots Blower Sizing
Old 05-15-2015 | 04:39 AM
  #121
Originally Posted by ICDEDPPL
What about idle quality with such a big blower..
efi and whipple and it will idle at 850rpm.even w/ massive wheels.
sutphen 30 is offline
Old 05-15-2015 | 08:23 AM
  #122
Yup, with the bypass valve mikes idles like a dream.
ICDEDPPL is offline
Old 05-15-2015 | 08:47 AM
  #123
Am I the only one that thinks the Whipple website isn't very helpful?
Cole2534 is offline
Old 05-15-2015 | 10:16 AM
  #124
The tech line is just as bad
Unlimited jd is offline
Old 10-03-2018 | 01:48 PM
  #125
14 apache's Avatar
Originally Posted by MILD THUNDER
I have a copy of the dyno sheet here. Actually we never did see the HP peak. But, at 6000RPM, they made 964HP. At 6500RPM, 985HP. The torque was outstanding though, from a 522ci engine.
was this on pump gas or race fuel?? Thanks
14 apache is offline
Old 10-03-2018 | 01:50 PM
  #126
93 octane from the shell station down the street
MILD THUNDER is offline
Old 10-03-2018 | 02:40 PM
  #127
F-2 Speedy's Avatar
thats pretty damn good for a 315 head and a small CID engine
F-2 Speedy is offline
Old 10-03-2018 | 03:02 PM
  #128
thats the beauty of forced induction ..heck look at the outputs of a modern turbo diesel. Most arent even barely over 400 cubic inches .
Old 10-04-2018 | 01:54 PM
  #129
I'll start with the 174 B&M. This is a straight, two lobe, teflon tipped supercharger. It's primary introduction, back in the 1980's, was for low RPM, low power smog era 454 Tow engines. This blower worked very well on a low rpm engine, that was simply looking to add a little more grunt down in the idle to 4000RPM range. It worked well in that application. This blower utilized a single carb setup. Was also used on the old Hawk Marine 525 engines. This blower should be limited to about 5lbs of boost on a 454ci marine engine, if it must be used.
So this is my exact setup. I have a 174 on a Hawk 525. What would you suggest to increase 100 HP.
RBeyer is offline
Old 10-04-2018 | 02:10 PM
  #130
6-71, 8-71, or a 420 megablower. Some better headgaskets, .060 thick, and 7lbs boost.
