Smashed Plugs on fresh re-build, any advice? >
Old 11-17-2014 | 05:01 AM
  #71
Originally Posted by SB
Improper exhaust dimensions can / will add more reversion (intake + exhaust) tendencies esecially when at 'worst length'.
When the energy wave comes back to the valve and it's open...slurp.
Serious.
Very true. And an easy way to tell if this is happening is look at the intake runners / ports in the head if there is evidence of carbon then the cam, exhaust or cam &exhaust aren't right.
Black Baja is offline
Old 11-17-2014 | 07:37 AM
  #72
Full Force's Avatar
Following is just conversation:
Blow thru carb's aren't the most trustworthy thing on the open water.
I'm a diehard carb guy, but with blowthru's I personally would go EFI/ Agai, just personal opinion and conversation.
Basically I'm waiting for full report of this engine before I listen to what may have happened without evidence.
My buddys been doing pro charged 509's blow through for 7 years, no issues....
Full Force is offline
Old 11-17-2014 | 07:40 AM
  #73
Full Force's Avatar
Originally Posted by FIXX
Dont rule out your intercooler,,it might have a hole in it and injecting water into the carb..you said hard starting which the engine could have been trying to start on water with the fuel.. pressure test the cooler..
Does not take much to have leaks in the intercooler, pressure check it, my buddy has gone through 2 of them over 7 years... luckily he has tons of monitering on the boat and saw things not right before it failed..
Old 11-17-2014 | 07:44 AM
  #74
Full Force's Avatar
What was timing at? I didnt see that said anywhere, there are many things that cause this... timing is a huge factor people overlook...and plugs... but you guys got that..
Old 11-18-2014 | 10:16 AM
  #75
we have run blow thru carb setups(done properly) and had no issues...
ezstriper is offline
Old 11-18-2014 | 10:45 AM
  #76
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Exactly what I found when tearing down my HP500 . Wonder what was left on the table running the stock Gill exhaust .
the deep is offline
Old 11-19-2014 | 06:16 AM
  #77
I would imagine a good bit. When this occurs the cylinder is not getting cleaned out. A good clean mixture can't get into the cylinder and its going to re-burn the already spent charge. There are many factors that can cause this to happen bad valve springs/ valve job, exhaust, cam cylinder head ect ect. This phenomenon really has me wondering how beneficial it would be in a custom build to bolt the exhaust on the head and flow the head same with the intake. Based off those numbers then cam the motor. I think this would give the best package...
Old 11-19-2014 | 10:58 AM
  #78
the deep's Avatar
Fast Singles Club
I was at 300 hrs. on the valve springs . It also appeared the head gaskets were seeping between cylinders . It was definitely time for a refresh/power upgrade .
the deep is offline
Old 11-19-2014 | 11:03 AM
  #79
SB
Don't waste your time with flowing headers. Use proper dimensions and you are good to go.
One thing that does make sense to flow on an exhaust is the muffler...if it has one..
Edit in: a 'spent' charge cannot reburn. It does, however, occupy space that fresh air/fuel should be occupying, and thus will be down on power.
SB is offline
Old 11-19-2014 | 11:06 AM
  #80
SB
BTW: I learned the hard way many years ago that I was losing almost 40hp on a mild 375-400 SBC.
It was the headers - wanna guess how ?
It's something I have never overlooked since then and I have seen it as an issue almost a dozen times since then.
SB is offline
