Midrange and low RPM grunt. Discuss please. >
Old 11-09-2014 | 08:27 AM
  #31
SB
It's all about how much air get's in the combustion chamber.
More cid's has more demand and room for more air. It doesn't necessarily get you more air.
SB is offline
Old 11-09-2014 | 08:46 AM
  #32
More cid's has more room for more air. It doesn't necessarily get you more air.
especially when cslob grinds ones.most air left out in any cam he specs.<lol>
sutphen 30 is offline
Old 11-09-2014 | 08:59 AM
  #33
Originally Posted by Full Force
A buddy of mine just did 502 CI engines with fully ported Edelbrock oval ports, 9.5:1 compression Cams from Bob M. and 850 CFM carbs, did 621HP and 644Tq, I forget rpm, but those are good numbers for N?A 502's... its all in matching parts up good...
Couple key things there. Key word, fully ported. lol.
Mike Tkach has done a few 502 Builds using the edelbrocks and had similar power number results. Around 600ish, but the heads had no port work.
I think the edelbrock heads are a decent bargain, but they are simply not that great of a head for moving air. Their new E CNC heads look impressive though.
Heres a nice article with a 502 with AFR 315 heads. It does have a fairly aggressive solid roller, , but 740HP from a 9.6:1 502 engine is pretty good!
http://www.sporttruck.com/techarticl...ylinder_heads/
MILD THUNDER is offline
  #34
If you are going to discuss low and mid range and how it relates to performance and economy it would be interesting to see what the actual load is on the prop roughly per RPM and relate it to the HP/torque of the engine at that RPM.
hotjava66 is offline
  #35
Full Force's Avatar
Originally Posted by MILD THUNDER
Back in the 70's, they used to install "Economy" meters in cars. I remember as a kid our family car was a 1975 Bonneville. In the instrument cluster, it had the "economy" gauge. It started out in the green while cruising down the highway. Upon acceleration, it would swing towards the red. Harder you accelerated, further into the red it got. lol, all it was, was a vacuum gauge.
High vacuum=low load
low vacuum= high load
To get back on topic though, there is something to be said about having an engine package that operates efficiently in your cruise range. Like I stated earlier, you wouldnt want to slap some huge 345/360cc port heads on a mild 454 engine, with a cam that would make peak power at 7000RPM, in an engine you don't plan on spinning past say 5400RPM.
There are alot of options though nowdays, as far as engine combinations, that give you a bit more flexibility. We have great valvetrain components available, that will allow you to safely turn that smaller CID engine, a bit faster to make up for its lack of CID.
I'll use my friend Joey's engines we recently built up as an example here. He had 522ci shortblocks to work with. Really nice components in them. He had Lunati Signature series blower crankshafts, oliver connecting rods...He like any of us, wanted to make good power. He had his sights on 1000HP.
Him and I talked alot about his build options. At the time, he had Edelbrock marine performer heads, and was purchasing 1071 blowers and intercoolers. I just knew, his edelbrock heads were not going to allow him to meet his goals, at least without an insane amount of boost that is.
A couple of his buddy's told him he really needs to go to a 4.25 stroke, to make them 555ci. I disagreed, and thought he could hit his goal, but it would take the right cylinder head/cam/boost/rpm combo.
Thats when I recommended he get in touch with Bob Madera, and look into some AFR heads, cam, etc. After working with Bob, Joe decided to go with the AFR 315 cylinder head, Bob did a cam for him, and the right valvetrain components to go with the setup.
When it came down to dyno day, the results were what we hoped for. The engines made their target number, within the target RPM/BOOST levels. The torque was outstanding as well.
Now just for comparison purposes, or to go deeper into all this. Our other buddy had recently dyno'ed his blown combo. His was a 540ci, 345 Dart heads, also a 10-71 blower (its what he had to work with). While this build had the cubic inch advantage, it made less power. With both engines at 8lbs of boost, the smaller 522ci, made 37 more HP at 6200RPM, and quite a bit more torque thru the rpm band. Same dyno, same dyno headers.
One would think that the larger engine would have made more torque, along with more power. I was really surprised at the torque production from this 522, not only was it a very flat curve, the numbers were really great for what it was. The key was the 522 simply had a better package. With that being said, the iron headed 540ci making 893Hp at 8lbs of boost, is/was nothing to turn you're nose to. Its just a comparison. But if they were both 540ci, Joey's engines, would have made around about 70HP more lb for lb of boost. Keep in mind those 345 Darts, are tremendously better at moving air, than a GM rectangle port casting. So, if that 540ci deal had a set of GM heads, that 37HP gap, probably would have been closer to a 137HP gap. Point, theres more to building a good package, than simply throwing cubic inches at it. Same goes for N/A engines as well.
Full Force is offline
Old 11-09-2014 | 09:19 AM
  #36
It would be interesting to see if my 540`s would close that gap vs. Joey with:
1. Wedges to increase velocity
2. Same (bigger carbs)
3. intercooler or matching intake temps
4. same compression
5. Bob cam
Last day today before I put the winter cover on Joe, sure you don`t want me to pull it so we can experiment?
ICDEDPPL is offline
Old 11-09-2014 | 09:35 AM
  #37
502ci stock crate GM. 245/250 112LSA cam, with .650/.650 lift. Not a small cam, but not a rediculous cam either. For those who don't want to read the full article, I'll sum it up here
AFR as cast 325cc with CNC chamber option. 665HP/593FT lbs 3500RPM=540 ft lbs
Brodix 294cc Race Rites. 634HP/582 FT lbs 3500RPM=531 Ft lbs
Dart 335 Full CNC . 660HP/589FT lbs 3500RPM=534 FT lbs
Edelbrock performer RPM 315cc. 616HP, 566 FT lbs . 3500RPM 523FT lbs
RHS 320cc .638HP, 584 FT lbs. 3500RPM=531 Ft lbs
Trick Flow 320CC. 655HP, 587 FT lbs. 3500RPM=527 FTlbs
Merlin 310cc. 631HP, 581 FT lbs. 3500RPM=531FTlbs
As we can see here, the torque production, at 3500RPM, is very similar. Highest number of 540FT lbs, and lowest number 523FT lbs. 17ft lb difference. But, lets look at the HP. 665HP, vs 616HP. Lets call that 50HP. In a boat engine, 50HP peak, is not peanuts. Lets say we installed this combo in a boat, let say a 35 Fountain. with the edelbrocks, and it ran 80MPH top speed. Going with say the AFR 325, it wouldnt be a stretch to pick up 200RPM per engine by doing so, with the same props. Possibly a solid 2-4 MPH gain, simply by choosing a better cylinder head. An 80mph boat, vs and 83mph boat. The gains would prob be even higher if we were talking going from a stock GM 502 mag head. Now, of course theirs a cost comparison to consider. If you have a perfectly good set of heads now, upgrading may not be worth it to you. But, if youre building from scratch, going from the cost of an Edelbrock performer head, to say a as cast AFR head with CNC chamber option, is really a no brainer, in my opinion. The Dart CNC head is an excellent cylinder head, but they are not cheap. The Trick flow 320 appears to be a good bargain as well.
Its very easy to get caught up the port sizes and shapes, and how we've always been taught that small ports = more torque, big ports =more upper HP. As you can see in this test, the larger port heads, just happened to make the same, or more, torque at 3500 than the smaller port heads, and the largest port head, did not make the most upper RPM HP.
http://airflowresearch.com/articles/article131/A-P1.htm
Old 11-09-2014 | 09:37 AM
  #38
This posting time stuff is getting annoying!
Old 11-09-2014 | 09:43 AM
  #39
Full Force's Avatar
oh yes for the edelbrock are good fully ported, out of the box I hear good things about AFR, never used them yet but many buddys have with great results, I had to do lots to the pro comps that came on my engines to kae them right, you know that story though...
ever hear anything on those cams your buddy has?
Old 11-09-2014 | 09:52 AM
  #40
4. same compression
5. Bob cam
Go for it! Yank them fukers out.
Theres no doubt making the right changes can improve or make more power on your setup. The purpose of my example, was to show its the combination of parts, can be of more benefit than simply cubic inch displacement.
