-   -   Oil restrictor size hp500 (https://www.offshoreonly.com/forums/general-q/320041-oil-restrictor-size-hp500.html)
SB 11-11-2014 06:00 PM
Rbesola -
Let me be frank here. Sorry Frank !
Will you please answer my question on oil psi I asked earlier. We need to clear this up to see if you even have a psi problem.
Plus, I'd really like to take off my helmet and leave the corner so I can go home.
Thank you.
SB 11-11-2014 06:32 PM
Originally Posted by Rbesola (Post 4217850)
Oil psi is good in the 75psi range running, 50ish idling. When I say I lose some oil pressure I don't mean zero, but it drops to 20-25 very briefly if I pull back hard which is enough for the light to come on which made me nervous. Not that I ever do but just for the sake of figuring out the issue. Also I just have some cheap push in breathers and thinking maybe a baffled valve cover or a little more length might solve some of that.
Okay...so....at the end of the 2 minutes at 6,000 rpm you are still at 75 psi ?
And right after this run you are at 50 psi idling ?
Your worry is a drop to 25lbs right when you pull the throttle back abruptly ?
Do I win a booby prize for insisting on this when/where/why/how oil question ? LOL.
I'm now not seeing an oil psi problem.
On to the other part:
You have non baffled valve covers and possibly a non baffled breather ?
Rbesola 11-11-2014 06:38 PM
Rbesola 11-11-2014 06:46 PM
Originally Posted by Black Baja (Post 4217812)
What temp is 180-190? Oil or water?
Also, what exactly are you motors?
Oil temp. Motors are mostly hp500s with the exception of 7.6cr je pistons, Manley h-beam rods crane cams and some arp hardware with mega blowers on top. Balanced rotating assy. Stock windage tray. No screens. Basically just back to what it was aside from what I listed.
Black Baja 11-11-2014 07:47 PM
You definately have an issue or issue. With a high volume pump your oil pressure should never be 50 at idle. Something is wrong. What kind of oil filter are you using?
Black Baja 11-11-2014 07:50 PM
Helmet on and back in the corner.
SB 11-11-2014 07:53 PM
F*k !
SB 11-11-2014 07:58 PM
I took the idle comment not literally...as in a maybe low to mid 1000rpm in gear. Not a sub 1k idle/idle.
You thinking psi reg spring/disc hanging up ? Nah, cause this wouldn't increase psi at low rpm.
Bigger helmet this time.
Black Baja 11-11-2014 08:05 PM
Hey helmet boy with a HV pump at idle not 1000 rpm. That's way off idle it should have 70 psi + I think mine is 80@ 500 rpm 90 WOT after 30 miles of 6000 rpm and back to idle still have 80. There is something wrong. Might be something stupid like a Fram (non HP) filter...
Black Baja 11-11-2014 08:27 PM
Originally Posted by buck35 (Post 4217904)
Been watching this, and it just occurred to me that if you're ole, I didn't say it , is being whipped into a lather with air bubbles that would certainly affect pressure.
Possible but I don't see it getting whipped at idle unless he thought he would make his own 14qt pan out of his 8 qt pan by adding 6 more qts of oil.
